Fuel Filter
Old Jun 26, 2011 | 08:49 PM
+fireamx's Avatar
Default Fuel Filter
Has anybody had their fuel filter changed at the dealer? If so, was it very expensive?
Old Jun 26, 2011 | 09:09 PM
Default Re: Fuel Filter
Maybe you have other ideas, but it is very very easy to change for a DIY.
Old Jun 26, 2011 | 10:45 PM
+fireamx's Avatar
Yea, I may tackle it myself James.
Anybody know what a "factory" filter price is?
Would a Mercedes SLK filter work?
I understand a dirty filter makes the fuel pump work harder, and that's usually the reason the fuel pump goes bad.
Besides running with the gas tank too empty.
Old Jun 26, 2011 | 10:49 PM
I would not hesitate to use a MANN filter. Chances are that is what you have already with a MB part number. Check here for some ball park figures:
crossfire filter fuel | eBay
Here is the PN# for the filter
Old Jun 26, 2011 | 11:05 PM
+fireamx's Avatar
Thanks James.
Old Jun 27, 2011 | 12:09 AM
tighed1's Avatar
Yep. Very easy x2.
Just do it!
Old Jun 27, 2011 | 06:28 AM
Yep. Very easy x2
I have had a new filter for a few months, but when I took a look at replacing mine, I see those factory squeeze clamps on all the hoses. What do you do ? Just cut them off and reuse screw clamps ?
Old Jun 27, 2011 | 11:50 AM
Mimi05SRT6's Avatar
I replaced mine with a purolator a few months ago. It gave me that extra power to tear down the strip!
Old Jun 27, 2011 | 05:41 PM
Chris L.'s Avatar
Olathe Chrysler (KC area) wanted $299 to install a fuel filter & $140 for an oil change.......= $439
I bought a Mann fuel filter & provided the oil & oil filter....local labor.....total parts (FUEL FILTER + OIL FILTER + OIL) & labor = $149
Old Jun 27, 2011 | 07:49 PM
You can find the Mahle fuel filter, which is most likely another source for the factory OEM unit, for 15-20% less than the Mann filter. Just do a search for the Chrysler Crossfire Fuel Filter and quite a few websites pop up that list both versions. The Mann will be $55-$60; the Mahle will be $40-48. Both are typically stocked.
And if you look around in eBay, per the link above, you'll find quite a few sources of fuel filters at even lower costs. Sticking to a Mann or Mahle in this application is probably not necessary. Just about anyone's filter will work. Heck - most are made by only a couple of suppliers and then labeled with someone else's part number.
Later,
Old Jun 28, 2011 | 12:53 PM
Alzilla's Avatar
I just had mine replaced yesterday. Part + labor was $160. In all honesty, I could've probably done it myself but I'm running out of space in my garage and I don't particularly fond of playing with fuel.
Old Jun 28, 2011 | 01:28 PM
Thirteendog's Avatar
Rob has the filters. i think they're $40. Super easy to change since you don't have to drop the gas tank to do it. Look under your car. You'll see it's not far from the gas tank.
http://www.needswings.com/Bosch--Mah...024773001.aspx
Edit: My bad, it's $55
Old Jun 28, 2011 | 02:58 PM
MikeR's Avatar
The filter and pump are mounted right next to each other, just inboard of the right rear wheel. Hidden by a plastic cover. Easy to change out, just have to clamp the lines and relieve the fuel rail pressure before you disconnect to minimize the fuel loss..... oh, having several rags under there with you is a good idea..
Old Jun 28, 2011 | 08:28 PM
+fireamx's Avatar
Guys thanks for all the info, this forum is the Best.
Old Jun 28, 2011 | 08:51 PM
Also remember - No Smoking.
Old Jun 28, 2011 | 09:01 PM
32krazy!'s Avatar
just bought a bosch filter off ebay for 35$ shipped
Old Jun 28, 2011 | 09:28 PM
+fireamx's Avatar
Great advice...... even for people not working around gasoline.
Old Jun 28, 2011 | 09:57 PM
ZAHANMA's Avatar
Just bought a new filter from Rob. Hopefully will be here by the end of the week so I can get it installed before Carlisle.
Old Jun 29, 2011 | 01:14 PM
dinasrt's Avatar
[quote=ZAHANMA]Just bought a new filter from Rob.
I buy these from Rob also. We want to keep Needswings in buss. A few extra bucks is worth the piece of mind knowing the right/good stuff will be coming to my door. I'm loyal to great service over the lowest cost; most of the time anyway.
Old Jun 30, 2011 | 12:03 PM
dmajma's Avatar
I called the MB dealer in Bend, OR and the parts dept quoted me $12.99 for the fleece filter and about $130-$140 for an oil change, including filter, and it also included washing and vaccuming. I have an "05 roadster.
Doug
