Washer Fluid Jets Not Working
Old Jun 27, 2011 | 10:33 PM
jekyll919's Avatar
Default Washer Fluid Jets Not Working
I just got my 2004 XFire on Friday, and discovered today that the washer fluid jets don't work, which kind of sucks. It's at the dealership right now getting the brakes tweaked (hopefully that'll solve the BAS/ESP light, but that's a different story). Anyway, I let the dealership know about the jets, but was wondering if anybody else has ever had the same issue. And by the way, I just refilled the washer fluid because I thought that was the cause, but it wasn't. Thanks in advance!
Old Jun 27, 2011 | 10:39 PM
Default Re: Washer Fluid Jets Not Working
I am not sure what "tweaking" the brakes involves, I would be curious to know.
As far as the washers, can you hear the pump run when you try them? Have someone stand by the passenger fender while you try it and listen. If you can hear the pump run, maybe the nozzles are clogged. If it isn't running, maybe a bad pump, switch, or connection.
Good Luck. James
Old Jun 28, 2011 | 09:17 AM
jekyll919's Avatar
I'll be sure to check that when I get the car back, but as far as the brakes go, I meant that they're making sure the rotors and pads work properly, because that's what the reader told them was causing the BAS/ESP light. I guess I should have been more specific.
PNA
Nov 12, 2020 04:44 PM
chturner
Jul 24, 2015 04:47 PM
Romio
Jul 24, 2015 07:03 AM
Zoodust
Jul 16, 2015 06:17 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
