Brake Pad Replacement FAQ - porterfield
Old May 30, 2004 | 09:56 PM
DFWSBR's Avatar
Default Brake Pad Replacement FAQ - porterfield
Drew up a FAQ on replacing the front brake pads on the crossfire.
http://www.dfwsbr.com/crossfire/faq/porterfield/
Old May 31, 2004 | 04:13 PM
Sunny9850's Avatar
Default
Hi Adam,
the step by step looks good to me, but I think you may want to point out to install the new pads on one side, before pumping the pedal ;-) and reinstalling the caliper on the disk. :-)
Old May 31, 2004 | 06:12 PM
DFWSBR's Avatar
Default
ah.. probably wasn't such a good idea to get up and leave the house for a few drinks with the boys before finishing the FAQ
I'll review it and correct it! Thanks
Old May 31, 2004 | 06:28 PM
DFWSBR's Avatar
Default
ok.. its fixed
Old Jun 1, 2004 | 07:11 PM
Sunny9850's Avatar
Default
LOL...as long as you have the drinks after finishing the brake job and not before ;-)
Old Jun 2, 2004 | 09:26 AM
DFWSBR's Avatar
Default
It was easy work. 90 something degrees outside though. I had to finish quick. Only took about 20 minutes per side.
Of course drinks came after the install
Old Jun 2, 2004 | 11:19 PM
dirtboy's Avatar
Default
You didn't mention it, but I assume you put the brake pad sensor back in place? And the sensor doesn't require replacement, I assume?
Old Jun 2, 2004 | 11:21 PM
DFWSBR's Avatar
Default
Everything goes back in reverse order.
The sensor just slides into the pad and locks into place. It is a very simple design. Not much to it. You'll understand when you take it off.
Old Aug 17, 2004 | 10:27 PM
HDDP's Avatar
Default
I started a thred for aftermarket poduct in the techincal mods forum, could you post product # & price...
Old Nov 24, 2004 | 03:53 PM
rick333's Avatar
Default Re: Brake Pad Replacement FAQ - porterfield
I just noted the brake pad replacement that was posted 5-30-04.
One thing was missing that should be addressed which is when pushing back the pads for removal, you should crack the bleeder valve so that the contaminates in the fluid won't be pushed back in the ABS which, as you can imagine, is very expensive. Top up the brake reservior with Dot 4 as recomended by the Manufacture when finished.
Rick 333
Old Nov 26, 2004 | 01:01 AM
myfire's Avatar
Thumbs up Re: Brake Pad Replacement FAQ - porterfield
Thanks a lot!!!
Excellent instruction.
You should get paid for this.
Myfire
Old Oct 2, 2005 | 02:47 AM
My XF's Avatar
Hello Adam:
We really appreciate the time you are spending for the Crossfire Forum.
They are all very valuable information for me and I am sure to all of us who love our Crossfires!!!
I particularly appreciate the TSBs you put on front brake pad replacement.
Now, I need to do the rear brakes.
I am wondering if you happened to have some how-to advise on this somewhere on your website?
Thank you again and our best regards,
MY XF
Old Oct 2, 2005 | 09:29 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Originally Posted by My XF
Now, I need to do the rear brakes. I am wondering if you happened to have some how-to advise on this somewhere.
the rear pads are extremely easy to replace. the caliper doesn't even need to be removed.
BRAKE PAD INSTALLATION INSTRUCTIONS: (REAR)
Tools Required:
flathead screw driver
needle nose pliers
17 mm socket w/ extension (for easy of removing lug bolts)
floor jack
torque wrench
Steps to follow:
1.) Use a floor jack and tools to loosen lug nuts. (suggestion: use electrical tape around exterior lug wrench bore for added protection from scratches to your rims)
2.) Use a floor jack to lift vehicle so the tire is 2" off the ground.
3.) Remove loosened lug nuts with 17 mm socket and extension. (use electrical tape on this socket as well)
4.) Use flat screw driver to push piston clip to compressed position. Place screw driver in the back side of caliper between rotor and inboard pad. Twist screw driver against pad and rotor to move piston.
5.) Compress rear clip on back of caliper to remove pin (secures pads). The pin will tap out with a hammer once pressure is relieved.
6.) Brake pads can be removed from backside of caliper (they just slide out).
7.) Install new pads.
8.) Re-install clip.
9.) Re-install pin.
9.) Re-install wheel and tire. Hand tighten lug nuts with 17mm socket. Then tighten securely with lug wrench. Lower vehicle with floor jack and retighten lug nuts when vehicle is on the pavement. Torque lugs to 81 ft lbs.
10.) Start car and apply brake pedal repeatedly until pressure has built up. Drive as normal.
Old Oct 2, 2005 | 06:39 PM
ctsemicon's Avatar
Excellent "How-To" guide!
One thing I have always done on cars with the hex-head slider type bold (caliper rides in the bushing) is to, before re-assembly, carefully clean and VERY lightly lubricate the slider with a thin coat of synthetic grease so that it will move freely.
again, great post! cjt
Old Oct 2, 2005 | 11:15 PM
My XF's Avatar
Thank you very much, Andrew
and thank you too, ctsemicon!
Old May 21, 2007 | 01:55 AM
minojo's Avatar
Is this procedure the same with the SRT-6 brakes?
Old May 21, 2007 | 11:03 PM
My XF's Avatar
I am very sorry.
But I can't tell you if it is the same.
I really don't know that much about this system.
My XF
Old May 21, 2007 | 11:16 PM
RPM's Avatar
RPM
Moderator
No, it's not.
The rears are similar but the fronts require a star bit for the bolts. Not sure what size exactly.
Old Aug 2, 2014 | 07:00 PM
eruby's Avatar
WOW, The rear pads are the easiest brake pads I've ever changes. Thanks for the step by step instructions.
Tools Required:
needle nose pliers
floor jack
torque wrench
Steps to follow:
9.) Re-install pin.
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
Rooster98
Dec 24, 2015 10:59 AM
Romio
Jul 24, 2015 07:04 AM
Rooster98
Jul 21, 2015 12:39 PM
