Muffler Cut-off
Old Aug 1, 2011 | 12:26 AM
austinboyette's Avatar
Cool Muffler Cut-off
Hey yall, I was wondering.....Could you cut off the muffler and weld the exhaust outlets back on and still sound good? I like a good sound, It has a good sound now, but I would like a little louder. Need some advice.....
Old Aug 1, 2011 | 01:01 AM
Kolme's Avatar
Default Re: Muffler Cut-off
I wouldnt do it like that... Instead, I would have someone cut out a section prior to the muffler and install an exhaust cutout. You can buy an electrical unit that can remotely open and close the exhaust butterfly door from within the cabin, allowing you to raise or lower your exhaust sound. Just make sure that you buy a good butterfly cutout, price dictates quality with them.
(im answering all your questions tonight! woohoo!)
Old Aug 1, 2011 | 02:29 AM
Infinite's Avatar
my car sounded awesome straight piped... do it
Old Aug 1, 2011 | 01:51 PM
Toolman's Avatar
In Pennsylvania your car will fail the annual safety inspection if an exhaust cutout is installed. If you plan to install one check your state inspection laws.
Old Aug 1, 2011 | 03:23 PM
Kolme's Avatar
wow, even with it closed??? In Texas we just require the cutout not be before the catalytic converter, although notbody really gives a hoot.
Old Aug 1, 2011 | 06:07 PM
Toolman's Avatar
In the PA inspection procedure document it says to reject if "there is a muffler cutout or similar device."
Old Aug 1, 2011 | 06:10 PM
TomStratRT's Avatar
There are clips on YouTube of the Crossfire minus a muffler. Sounds like poo.
Old Aug 7, 2011 | 10:29 AM
killerkanadian's Avatar
I'm new here and all. I just bought a 04 crossfire and have been using these forums for a quick reference on a lot of things.
One thing i will add to this thread though, is that i cut my muffler off in the back and y-piped it to some duel crome tips. Even if you kept the stock tips on, which would require some cutting and welding of your old muffler, i think no muffler sounds great. I can't compare it to magnaflow or borla exhaust system but the sound is almost perfect with out the muffler.
Sometimes you get a little bit of a backfire rumble too.
Also something to note, the car sounds totally different under a load (driving) than just reving in neutral so some of those videos don't always give you the best idea.
Old Aug 7, 2011 | 01:50 PM
I would say a good muffler shop should be able to cut off the muffler, install a Y pipe, then weld your original tips back on with not much effort.
James
Old Aug 12, 2011 | 09:06 PM
I made this video just so i could hear the exhaust. I wasnt trying to show off or anything. But this is what my 04 n/a sounds like with a muffler and back cats cut off. The muffler shop just welded on a duel crome tip which hardly cost me any extra.
http://www.youtube.com/watch?v=sqnkiRtn5Tg
Old Aug 13, 2011 | 08:17 AM
TomStratRT's Avatar
Just as I said earlier, sounds terrible. I would hate to be your neighbor early in the morning when you fire that up. The Magnaflow is bad and it has dual mufflers. This is twice as bad.
Old Aug 13, 2011 | 08:25 AM
Well to each his own, but I'm probably going to throw a magnaflow on mine this coming week to try to tone out some of the high end anyways.
Old Aug 13, 2011 | 01:43 PM
sounds like an old pick up truck, but if that is what trips your trigger....there you go...
Old Aug 13, 2011 | 01:45 PM
Magnaflow won't do it, been there done that. Use the Ansa before you waste your money on the Magnaflow.
Old Aug 14, 2011 | 06:01 PM
Chucky B's Avatar
Hey buddy, I just did the exhaust on my crossfire and let me tell you. First just changing the muffler makes it sound like a loud 350z. When you drive it on the highway it has a bad drone at 4 grand. I had the exhaust shop put a resonator on it. Sounds great now, just letting you know about my experience.
Old Aug 18, 2011 | 03:03 AM
sasouky74's Avatar
I would say it is better a XF which hums that a suffocated(suppressed) XF.
Personally I put Borla and I am very satisfied with it.
Old Aug 18, 2011 | 09:10 AM
I RARELY disagree with James, but I had a magnaflow on my last one and liked it. It was quite a bit deeper and more throaty than the ansa, also more drone at points, but with the 6 speed, you just shift and problem solved.
If you want civility, magnaflow is not the way to go, but if you want to tone down what you have now, and make it sound a lot more tuned, try it....
TerryR
Dec 13, 2019 03:27 PM
xfireon20z
Oct 26, 2015 05:37 PM
Big_Country
Sep 22, 2015 03:47 PM
Sep 13, 2015 02:12 AM
xzmilan
Jul 22, 2015 10:40 AM
