Wind noise, and loose passenger window glass.
Old Oct 22, 2011 | 01:45 PM
Rockster's Avatar
Default Wind noise, and loose passenger window glass.
I've had my XF for several months now and since I purchased it I've noticed wind noise on the passenger side.
Upon closer examination, I can see that the passenger side window isn't aligned properly like the driver side. When I open the passenger side door, I can put my hand around the glass and lift....when I do this is slides up and slightly rotates from the back until it is in the position it is supposed to be in. The total play is maybe an inch up upward travel and 1/2 inch of rotational travel.
I've seen the TSB for adjusting the window but I'm not sure if that applies here and I'm not crazy about taking the door apart. Any thoughts on this?
Thanks, appreciate any input.
Rockster
Old Oct 22, 2011 | 02:17 PM
Default Re: Wind noise, and loose passenger window glass.
Rockster
The inner door panel will have to come off to fix this. There is adjustment from the bottom of the door but not for what you want.
See this thread.
https://www.crossfireforum.org/forum...tml#post477487
Old Oct 22, 2011 | 03:18 PM
Rockster's Avatar
See this thread.
Thanks for the reply, it is wat I expected but hoped to avoid. Quick question - do you know offhand which screws adjust that movement?
R
Old Oct 22, 2011 | 03:52 PM
Rockster's Avatar
Actually, I've looked at this much closer and I see where the adjustments need to happen.
Thanks!
R
55chevy
Jul 22, 2024 02:31 PM
usprb1976
Apr 4, 2024 04:57 PM
nataliefs
Oct 5, 2015 01:03 PM
Posimoto
Sep 13, 2015 06:13 PM
jaesa
Sep 7, 2015 01:50 PM
