bad relay
Old Oct 28, 2011 | 04:17 AM
blackpepper's Avatar
Default bad relay
I notice my airpump running a lot lately.It came on last night several times so I pulled tje 40amp fuse at 4am.
Old Oct 28, 2011 | 06:00 AM
robby363's Avatar
Default Re: bad relay
Maybe it's just the 96 Volvo pump you used for a replacement.
Old Oct 28, 2011 | 06:17 AM
You could be right if it had a built-in power supply. I will try to locate some small files at Lowes and sand paper for some contact cleaning.
Old Oct 28, 2011 | 06:59 AM
robby363's Avatar
I was just being sarcastic about using the Volvo pump. It's not uncommon for the pump to run when you're stopped or at a red light. There's also a solenoid,2 switchover valves and a check valve that controls the pump.
Old Oct 28, 2011 | 07:46 AM
Using files and sandpaper are not to be recommended. If it is the contacts that are at fault you should use very fine abrasive cloth and leave a polished surface. These contacts are polished for a reason and you should attempt to do the same. Leaving a rough spot means you will be doing it again too soon.
If you have a rough surface the spark can arc across any rough high spot and pit that area, a smooth and polished surface is less prone to pitting.
Old Oct 28, 2011 | 09:39 AM
tighed1's Avatar
Yo 180 (others)
Did we ever find a supplier for the relays?
A lot of the ones I am seeing are burnt and pitted so there's not a lot I can do 'cept clean up the mess that is there.
Old Oct 28, 2011 | 04:06 PM
Kodebuster's Avatar
In my electronic repair day, I would use a fine emory cloth on relay contacts.
Not sure if this was the best approach, but many of my computer co-workers at the time used the same technique...
Old Oct 28, 2011 | 05:24 PM
The finer the emery the better.
Old Oct 28, 2011 | 05:29 PM
Originally Posted by tighed1
Yo 180 (others)
I looked up the part number and its in the following post.
https://www.crossfireforum.org/forum...tml#post550548
Old Oct 29, 2011 | 06:23 AM
I know you was joking, upon inspection my contacts are pitted.I will attempt the cleaning procedure such a small area any special techniques.
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
