Headlight bulb replaced but light won't work
Old Oct 28, 2011 | 12:39 PM
nickwe21's Avatar
Default Headlight bulb replaced but light won't work
Hey guys!
So I replaced the headlight bulb (driver side) this morning BUT nothing! No light at all. I know it's the right bulb (H7) - what am I missing?
Thanks for any help --
Nick
Old Oct 28, 2011 | 12:57 PM
Default Re: Headlight bulb replaced but light won't work
Originally Posted by nickwe21
Hey guys!
Nick
1, You did put the new bulb in and not the old one?
2, Did you pull on the wires to remove the socket? In which case you could have broken a connection
3, The new bulb could be broken already, run a meter on it or something to test the element.
Old Oct 28, 2011 | 12:59 PM
robby363's Avatar
Does the high beam work on that side? If it works check fuse #8 in fuse box that's on the side of the driver side dash panel. It should be a blue 15 amp fuse.
Old Oct 28, 2011 | 01:11 PM
nickwe21's Avatar
Just checked it, the high beams are working on both sides,so I guess I did not hurt the connection, did I? It just started to rain - so I might have to postpone this project till later on. BUT I have to drive to Miami, so I guess one light will do - got the feeling this means getting pulled over on the Highway lol...damn it!
Old Oct 28, 2011 | 01:20 PM
The socket you pull for the low beam bulb would only affect that bulb, no other.
Old Oct 28, 2011 | 01:49 PM
nickwe21's Avatar
You guys are awesome! It was the fuze - replaced, works! Thanks so much! Heading down to Miami
Old Oct 28, 2011 | 03:02 PM
Does this mean the old bulb is OK?
If a fuse blows it's best to know why it blew.
Old Nov 1, 2011 | 02:53 PM
nickwe21's Avatar
No the bulb was definitely broken and so was the fuse. Will keep an eye on it. Everything seems to work out fine now, the light shines a bit low to the ground so today or tomorrow whenever I get the chance I will play around with the bulb again to adjiust it to the right position!
Old Apr 10, 2012 | 02:53 PM
Mrmiata's Avatar
Another satisfied customer! I love it.. lol.
Old Feb 18, 2018 | 12:59 PM
Aprilc1235's Avatar
what if the high beams on that side still doesn't work. ? Neither does the low beams . Can anyone help me
rayth
41
Jul 31, 2019 04:02 PM
amatxcrossfire
Aug 15, 2015 01:28 PM
chturner
Jul 1, 2015 10:16 PM
carmax
Jun 18, 2015 01:30 PM
Brian
Nov 20, 2003 07:33 PM
