Oil Pressure Project
Old Nov 20, 2011 | 05:31 PM
hcarter's Avatar
Default Oil Pressure Project
Pressure Port
Removing plug
Open port and plug
Banjo and 90 -3AN ,stainless Teflon Line installed
Plenty of clearance from belt
line covered and mounted to Mani using Billet Wire Seperators
Finished install
NO Leaks ,gauge working great first started the car OP @ 80 psi for 30 seconds then gradually dropped to 45 and stayed there . HAPPY CAMPER
Old Nov 20, 2011 | 07:07 PM
Default Re: Oil Pressure Project
Nice job Howard.
When I saw you were using SSbraided line, I thought you were going with a mechanical gauge. I assume there isn't enough room to install the sender on the engine?
James
Old Nov 20, 2011 | 07:45 PM
LantanaTX's Avatar
Great post! Looks like a great place to tap oil pressure for a turbo
Old Nov 21, 2011 | 05:06 AM
hcarter's Avatar
James . I couldn't really find a suitable spot on the engine , I had thought about the location of the rubber bushing (for lack of a better word) that help hold the stock enjine cover down , but decied to run it back to the firewall. this was a fairly easy and clean install and is well out of the way of the belt if the belt where to break or come off it would not effect the fitting . pull the fan and belt and your there.
Lantana TX , , Probably so
Old Nov 21, 2011 | 06:56 AM
maxcichon's Avatar
Very nice. VERY nice. Clean and simple,
Parts list? Part numbers? Vendors?
Old Nov 21, 2011 | 07:44 AM
hcarter's Avatar
Max
Here you go.
1--12M BANJO TO -3 MALE 458054 6.95
SHORT STEEL EA.
1--12M X 1.5 BANJO BOLT 458046 10.99
STEEL EA. krush washers included
3ft-3 High Pressure Teflon 620003 3.50
Hose (per foot)
1---- -3 Straight fitting Teflon Hose 600003 6.59
End Steel
1/8"P FEMALETO -3 STEEL 711003 6.62
GAUGE ADAPTER
1--- -3 90 TEFLON HOSE END - 609003 11.69
STEEL
6 PARTS IN TOTAL .
JDA Interprizes . Website jdaent.com
The line holders on the mani is just billet plug wire seperators ,,any parts house will have these ..fairly cheap.
Old Nov 21, 2011 | 08:18 AM
This looks pretty good for the gauge , sender & wiring : ( $64.99 w/free shipping )
Blue Digital LED Oil Pressure Gauge
But you are correct, need the banjo with 90 degree bend and the bolt specifics .......
( also, where the heck do you put the gauge ????? ) - never mind on this too. I see hcarter's sig says "Tri Pillar Pod w/GlowShift Gauges"
never mind, posted AFTER hcarter replied.
total cost : @ $50 for hardware, $65 for gauge = $115
Old Nov 21, 2011 | 10:16 AM
MikeR's Avatar
Howard,
that is a GREAT install job.... I actually have 3 banjo bolts here as I was trying to find a better way to do that too.... so now I have another option if I decide to add an oil gauge later......
Old Nov 21, 2011 | 10:20 AM
maxcichon's Avatar
Originally Posted by hcarter
Max
Here you go.
SHORT STEEL EA.
Hose (per foot)
End Steel
GAUGE ADAPTER
STEEL
6 PARTS IN TOTAL .
This will be a great help to all!
Thanks for this...
Old Nov 21, 2011 | 05:05 PM
32krazy!'s Avatar
is there a way to add an electrical sensor to run into my dashdaq?
Old Nov 21, 2011 | 05:24 PM
hcarter's Avatar
If you have a ziltronix with your Dashdaq you can.
Old Nov 21, 2011 | 05:46 PM
32krazy!'s Avatar
i have it. run the setup you have to a sensor then in to the zt-2?
Old Nov 21, 2011 | 06:31 PM
hcarter's Avatar
That should get you a reading to your daq . Rudy can get you in the right direction as far as a sensor.. I'm running mine to a gauge ,with the fuel rail pressure, and Boost ,everything else I get from my daq,
Old Nov 21, 2011 | 09:45 PM
MikeR's Avatar
Steve,
That is what I would do(some day).... run an AEM 10bar pressure sensor output to the Zitronix...
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
