HI Oil Warning Question
Old Dec 1, 2011 | 03:43 PM
AG SIZZL's Avatar
Default HI Oil Warning Question
I searched past threads about this warning but did not see my circumstances.
I had the oil changed about three months ago on my 2004 and was told they used Mobile 0-40 oil. Today I got the first HI oil level warning. Any idea what is causing it to suddenly appear without having a recent oil change?
Thanks
Old Dec 1, 2011 | 04:05 PM
arejohn's Avatar
Default Re: HI Oil Warning Question
Use the dip stick and check oil level and appearance. If normal warning system problem If actually high might be water from head gasket leak.
Old Dec 1, 2011 | 04:27 PM
AG SIZZL's Avatar
Based on the dip stick, the level is way high, but oil looks normal, Hard to tell.
Old Dec 1, 2011 | 05:47 PM
MikeR's Avatar
If you have access to a Topsider you can suck out some of the oil...... but the fact that it has been 3 months since an oil change and the Hi warning and increased oil level would indicate that something else has changed....
You could drain the oil into a pan and see if there is anything in it that you cant see on the dipstick....
Old Dec 1, 2011 | 08:00 PM
texas t's Avatar
My car did that after oil change and 2500 miles., took oil out, put oil in, showed hi then low. Mine. has a defective sending unit. Also the oil level was very hard to read on stick i had to look in owners manual before i figured out how to read level
Old Dec 1, 2011 | 09:50 PM
arejohn's Avatar
First time you get the oil real hot?
Old Jan 20, 2012 | 09:39 AM
user 739729's Avatar
Banned
Did you ever get this figured out? I'm experiencing the same thing. Got oil changed about a month ago and now I'm getting the HI oil warning and it looks high on the dipstick.
Old Jan 20, 2012 | 09:54 AM
texas t's Avatar
Smile Re: HI Oil Warning Question
I am having the oil level sensor replaced, Mine is still doing this as of now
Valk
Jun 22, 2025 09:15 PM
4drturbo
21
Nov 12, 2018 04:50 PM
lazorouss
Sep 11, 2015 09:16 AM
MickeyNasty
Sep 6, 2015 08:29 PM
PNA
Sep 5, 2015 02:20 PM
