Exterior lights
Old Dec 28, 2011 | 07:46 PM
lman's Avatar
Default Exterior lights
I had a problem. When I turned the headlights on, the brake lights came on! headlights off, brake lights functioned normally.
Checked everything for 3 days and spent hours on the Forum.
Don't know who said it, but someone posted that if you change an exterior light, change its mate also.
Went out and put two new brake light bulbs and PROBLEM SOLVED. Everything is working normal again.
Thanks to whomever posted that earlier thread.
Only had my 05 for 6 months.... LOVE THIS CAR
Old May 22, 2019 | 10:29 PM
Jo-Ann's Avatar
Default Re: Exterior lights
Hello
Need help please. Headlights are so dim that I can’t drive at nite. Can someone help me. Need to know where I can purchase
headlights that will light up properly. Ridiculous not being able to drive my Crossfire (2009)
Thanks for your time.
Jo-Ann
Old May 22, 2019 | 10:36 PM
Are they dim due to electrical trouble, or clouded lenses?
Old May 23, 2019 | 04:54 AM
Jo-Ann's Avatar
No not clouded lenses. I would like to purchase new headlights but I don’t know which ones to purchase. The ones that I have now seem like a yellow llghting. Definitely not driveable at nite, way too dangerous. I am French Canadian by the way not from the USA.
Would you have any suggestions?
Thanks
Old May 23, 2019 | 09:22 AM
zip439's Avatar
Many people here use the Sylvania Silverstar Ultras. I prefer the PIAA Xtreme White Plus avaliable at needswings.com
What you are looking for is an H7 bulb with a 4000k light spectrum (white)
My eyes are old and tired and had the same problem with the original bulbs. The 4000k will fix that.
Old May 23, 2019 | 09:24 AM
Thanks
The only thing you can replace is the bulbs if the housings are fine. Are you sure the headlights are pointing in the correct direction?
How long have you had the car?
I find the lights adequate as is but HID (high intensity discharge) lights are very white to bluish depending on what type you get.
I would check to see if the lights are aimed correctly before moving to HID lights.
Old May 23, 2019 | 10:12 PM
Jo-Ann's Avatar
Thank you so much for your help. Will definitely check this over the weekend. My eyes are also old and tired. Lol
Regards
Jo-Ann
Old May 23, 2019 | 10:21 PM
Jo-Ann's Avatar
Hi
I own a 2009 Crossfire. Even if the headlights are pointing in the correct direction, lighting is very low.
Is there a problem if HID lights are white to bluish?
Old Jun 7, 2019 | 03:28 PM
Jo-Ann's Avatar
Hi zip439 sorry don’t know your name.
Did you change the bulbs yourself? Was it complicated to do? Do we just change the bulbs or is more toi this?
thanks
Jo-Ann
Old Jun 7, 2019 | 04:35 PM
when u change the bulb be sure NOT to lose the spring clip a lot of people loose it and it holds the bulb in..
Old Jun 7, 2019 | 04:38 PM
zip439's Avatar
Yes, I changed them myself. It can be difficult but you can do it. There is a tutorial on this website.
Click this link: https://www.crossfireforum.org/forum...tml#post524311
Be careful with the wire clip. It can come out and then be a pain to install. Also watch how the bulb comes out. The new one will go back in the same way.
Old Jun 7, 2019 | 05:00 PM
There is a trick I read here on the forum, the high beam bulbs have the 'TAB' pointing up, and the low beam bulbs have the 'TAB' pointing down. Make sure the wire clip is seated correctly and all will be good!
Old Jun 7, 2019 | 09:43 PM
The main thing is that the tabs must sit in their pocket properly or the light will be pointing in the wrong direction.'
Old Jun 7, 2019 | 11:46 PM
So, high = up, low = down. Should be easy to remember.
2004_
Jul 9, 2025 12:39 AM
Danyuhl
Nov 2, 2019 05:18 PM
RojoGTO
Feb 6, 2016 11:14 AM
stlas69
Sep 3, 2015 10:28 AM
cryptic47
Aug 12, 2015 02:36 AM
