So is this rcm, and or the crank sensor/cam sensor problem basically a given!
I am just a curious about how common these problems actually are, I am a little worried about the price of maintenance!!! How many people here have been able to just drive the car with normal maintenance and go lets say 80/90k without any problems???
re: So is this rcm, and or the crank sensor/cam sensor problem basically a given!
The RCM problem can be addressed before any trouble occurs. Simple repair really. As for the other sensors mentioned, they fail just as often as other auto manufacturers, no more, no less. It just sounds bad because it gets mentioned here everytime it happens. One good thing is that you can replace it yourself using all the info posted on this forum. Oil changes are part of regular maintenance but are on the expensive side, more so if you have someone else do it. But I wouldn't let that deter me from buying a Crossfire. Tires can cost more for this car than the average daily driver, again still worth the cost for the enjoyment of the car.
James
James
Re: So is this rcm, and or the crank sensor/cam sensor problem basically a given!
Crossfire's with no or little problems
Going to a dealership and counting the cars on the hoists does not reflect the overall reliability of that makers cars. Just like hospitals do not reflect the health of the general population.
You would be better of not searching the web for symptoms of illnesses or you will start wondering why you are still breathing.
Im from owensboro ky,
Take a look: 5th Annual Spring 2012 Tail of the Dragon GTG - April 6-8, 2012
KDW4Him
18
09-01-2021 05:47 PM
oldvintagedude
08-14-2015 06:20 AM
