valve stem caps
Re: valve stem caps
They are special caps, but they did not have any logo on them. You must be careful to use the caps made of the same material as the stems. If not, they can corrode (electrolysis) on the stem and lock themselves on for good. I use plastic to be sure they don't lock on.
James
James
Re: valve stem caps
I had a cap get lost once and I topped up the tire pressure in freezing weather. I blew a chunk of ice from the stem into the valve body and it leeked. The upshot was that the tire was ruined, it was in deep snow and the ill effects of the flat tire was not apparent to me. Ruined the sidewalls. Dummy.
on
Re: valve stem caps
As I stated earlier, I use plastic caps painted with silver wheel paint so they don't stick out and no worry about corrosion.
I understand the valve stems are aluminum. With that in mind, I poked around and found several auctions selling aluminum valve caps with the rubber seal enclosed. I figured aluminum on aluminum would be fine. But then I read in the fine print that these aluminum caps are not compatible with aluminum valve stems? Why would that be? Can someone here have a reasonable explanation for this?
James
James
4drturbo
21
11-12-2018 04:50 PM
