Drive Clean Testing
Drive Clean Testing
Early Crossfire models will now need testing as they turn 7 & 8 yrs old. My '05 got tested for the first time today. Unlike automatic, front wheel drive vehicles, the Crossfire was measured at idle and low rpm. 2,500rpm to be exact.
Here are the three components and how the car performed.
HCppm Limit 150, Crossfire 39
CO% Limit 0.70, Crossfire 0.02
NOppm Limit N/A, Crossfire N/A
Thought it would be interesting to compare to other Crossfires as they are tested. Who has the cleanest engine?!!
Re: Drive Clean Testing
CO% Limit 0.70, Crossfire 0.02 ...............180, 0,03
NOppm Limit N/A, Crossfire N/A .............180. N/A
You lose!
on
Did you guys ever noticed that the test results are often not even close to the set allowed limits? In almost every case, it is because the test itself is often not performed properly. Running an engine at idle will not simulate a car at a red light, in Drive. Reving the engine in neutral or in gear will not simulate the conditions of a car accelerating, cruising and coasting accurately. The most accurate way to perform an Etest is by using a Threadmill.
I know, in my area anyways, I have not seen an Etest facility equipped with a threadmill. Is a threadmill a common sight in Southern Ontario? I have 2 vehicles so, every year or so, I witness the Etest technician reving and idling and taking samples that he thinks look good. Some places are only concerned with pumping cars thru to collect their fee and there's no faster way to do this then with a "Pass", right?
One thing is sure, if the Etests were done using the required tools and techniques, a lot more cars and trucks would fail, requiring emisions repairs.
Cheers to all SOCO members!
When I go on a medical clinics treadmill I get exhausted and if I farted maybe I would get "FAIL".
Originally Posted by Sandgrounder
Test not requied out West, untill the goverment find out they are missing a cash cow
on
on
Now Beaner I gotta ask...... What criteria would they use as a benchmark for a "PASS" when you have the only 5.5 Ltr Crossfire in Canada ? Were they scratching their heads at the Drive Clean Centre or did B. Hill just sign away?
I am pretty sure it goes by the vin #. Unless that changes... same test
on
Originally Posted by Beaner
they just filled in the blanks on the screen with 5.5L and 8 cylinders... and taa daa... those values showed up. No idea where they came from or what program Ontario driveclean uses. It might be the same criteria as the stock 3.2L engine??? And I got rid of the 2 rear catalytic converters and still passed easily
THAT was my next question.
Indelibility
08-27-2015 10:21 PM
