Parrot Asteroid Question
Old Mar 28, 2012 | 04:31 PM
AC/No DC's Avatar
Default Parrot Asteroid Question
Hello fellow Crossfire aficionados!
I'm about to pull the trigger on the Parrot Asteroid but I'm a little bit concern about installation. Can anyone that has one comment on how difficult it is to install and what parts are necessary for installation? i.e. receiver wire harness, etc.
Much appreciated gents!
Old Mar 28, 2012 | 05:24 PM
a7x6kse6's Avatar
Default Re: Parrot Asteroid Question
There is a sticky in this section specifically for this. Also the search tool is very useful.
Here is the link: https://www.crossfireforum.org/forum...et-stereo.html
Old Mar 28, 2012 | 06:12 PM
AC/No DC's Avatar
Thanks for your reply, I have searched and I have seen the "How To" guide. It's my mistake for not specifying. The thing is that I read that because it's an European product it doesn't need the receiver adapter, it fits right in without major "tinkering" and so I want to know if that's correct. The guide is great but it's mainly for American Stereos.
Cheers!
Old Mar 29, 2012 | 09:10 AM
a7x6kse6's Avatar
Cheers!
Parrot ASTEROID Digital media receiver at Crutchfield.com
If you buy the radio from crutch field they supply everything you need to install it in your car. If you look at the adapter for the antenna and the pictures of the back of the radio you can clearly see that the radio uses the standard antenna input that most aftermarket stereo's use. You need the same adapter that everyone else has used.
Old Mar 29, 2012 | 10:10 AM
mferreira3417's Avatar
everything you need to install this will come with it from crutchfeild
i also did the rear sub isolation and installed the rca jacks
used the amp preouts on new headunit
man this thing rocks very happy with it
Old Mar 29, 2012 | 10:58 AM
AC/No DC's Avatar
Alrighty then, guess I'm pulling the trigger! Thanks for the replys!
Cheers!
Old Apr 10, 2012 | 07:53 PM
Choppy's Avatar
If just replacing head unit its very easy. In the next few days i will pull my parrot out and take picture of wiring to show you how to hook it up.
Old Apr 11, 2012 | 04:33 PM
SRT6_Roadster's Avatar
What do you think of the Asteroid? How is the sound quality? I am debating pulling the trigger on one.
Old Apr 11, 2012 | 04:35 PM
AC/No DC's Avatar
That would be awesome Choppy!
Old Apr 18, 2012 | 11:29 AM
bruco1's Avatar
I installed an Asteroid a month or so ago.
Sound quality is much greater than stock unit which was my first goal.
The apps are weak and not the reason to get this unit. It is software driven and not hardware so it does crash once in a while, say 1 or 2 times in a week for me. Could it be better? Heck yes it has tons of potential but no way is it developed enough to reach it.
Install for me was painless, plugged right into my ISO harness (on a slk32, not sure if crossfire has exact same) just needed an antenna adapter.
Overall is it worth it? Sure, I like oddball stuff!
Old Apr 18, 2012 | 07:05 PM
Sounding better than stock is not setting a very high bar IMO. Do you have anything else to compare it to? I am debating between this, a Kenwood Excelon, and an Alpine unit.
Old Apr 19, 2012 | 10:24 AM
bruco1's Avatar
ok, the Parrot sounds WAY better than the stock unit using stock amp and speakers. Good dynamic range, good adjustabilty, imaging is so-so but that is compromised by speaker placements.
Is it as good as my Klipsch home theater? Not even close, but for an open roadster I am happy with it. I was never a fan of Alpines but the Kenwood I like. Really depends on what your objectives are. For pure sonic fidelity perhaps the Kenwood. If you want to mess around with tweaking and hoping for better Android apps, Parrot.
Old Apr 19, 2012 | 11:20 AM
Thanks that helps. I need to spend more time looking at the units. Sonic quality is important on the other hand a car esp. a roadster is a hugely compromised space. Almost as important as sonic quality is not having a dancing, flashing display. Personally I think a busy screen takes away from the atmosphere of the car. I do not believe that any of these units have this "problem"
I have actually been distracted and am working on braking upgrade. Now I just need to get the vendor to respond so I can actually purchase the rotors I want. Who knew it could be so difficult to spend money with someone.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
