SL-55 Nightmare... Install pointers??
Old Mar 29, 2012 | 08:42 PM
JHM2K's Avatar
Default SL-55 Nightmare... Install pointers??
For starters, the mounting tabs are a PITA... But that's a minor issue.
When you get the Y-pipe mated to the boxes, the inlet (to the supercharger) is at the wrong angle... Rubber opening is at a -45° and the s/c inlet is at a -70°. So, I worked backwards and secured the y-pipe to the s/c inlet, and THEN attempted to attach the boxes to the Y-pipe. The hoses and airbox exits are ovals, so it only works at one angle. Once the boxes were mated to the Y-pipe, I went to secure the boxes to the motor mounts and *POP* the inlet snaps off again because you have to bend the Y-pipe, putting pressure on it.
What's worse, is the worm-clamp won't tighten past a certain point, else it simply snaps and you lose all tension. Basically, you can mount the Y-pipe to the inlet, or the Y-pipe to the boxes, but not both. And I don't have the warm-fuzzies about going down the interstate and having the Y-pipe fall off, allowing the s/c to ingest unfiltered air.
The poor clip fitment is the least of my worries... the Y-pipe is my biggest concern.
So, gurus, where am I screwing up? SL55 veterans welcomed...
Old Mar 29, 2012 | 08:44 PM
Default Re: SL-55 Nightmare... Install pointers??
Well you know Johnny boy, when you start "cross dressin' " Stuff is going to happen....
Old Mar 29, 2012 | 08:53 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Mine came complete with the OEM SS clamps around the ovals and they stay intact. Unless yours has custom made fasteners for mounting to the motor mounts, do not try to get them to line up. Just place them parallel to the manifolds and use black heavy duty zip ties to fasten each airbox to the mounts or to the slots on the manifolds. Let me know if I've confused you as I could take some pics and email them.
Old Mar 29, 2012 | 09:36 PM
JHM2K's Avatar
The zip-tie trick might just work... Mine does have the OEM SS Clamps around the two smaller pipes, it's the clamp around the main pipe going to the S/C that's the issue.
Old Mar 29, 2012 | 09:43 PM
Thirteendog's Avatar
I don't understand why you're doing all this when all you have to do is send your car up to Rudy and have him put a supercharged V8 into it. Then your SL55 air boxes will fit.
Old Mar 29, 2012 | 09:48 PM
JHM2K's Avatar
Because if I did that, I'd still get beaten by grip-grip in the 1/4 mile. Being James May isn't a bad thing.
On your other point (in my facebook post): The SLK55 boxes won't work at all, there's no space for the blower.
Old Mar 30, 2012 | 04:33 AM
32krazy!'s Avatar
bring it to the house we can look at friday while im working on mine
Old Mar 30, 2012 | 08:07 AM
JHM2K's Avatar
Will do, I'd love to get these working
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
