Stereo problems Infinity
Old Apr 6, 2012 | 03:50 AM
biffcrille's Avatar
Default Stereo problems Infinity
The original stereo from Infinity is in the car.
On the stereo's display flashes the text "Chrysler". Many dealers I talked to has never heard of the problem, they think I'm going to push in a code. But none of the stereo keys respond when you press them, but the text "Chrysler" will flash on.
The error occurred the first time when I would start the car the first time after winter. It has not been run on all winter so the battery had discharged. Now I've had the battery on charge. So the battery is fine now.
I have also checked all fuses and they are also okay.
There was a car dealer who told me to disconnect the negative pole of the battery and leave it for 10 minutes to reset the unit. I have done this. But the text "chrysler" continues to flash.
Does anyone know the problem I would be very grateful for some help.
Old Apr 6, 2012 | 03:57 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Stereo problems Infinity
My bet is the battery is done. What is the voltage on the battery with the car turned off?
Old Apr 6, 2012 | 07:58 AM
biffcrille's Avatar
Thanks for your reply. I'll see if I get hold of any machine I will measure the battery.
But I can run down the roof and up again with the engine off. So the battery can not be completely empty. For I assume that it takes a little power when doing this.
Old Apr 17, 2012 | 11:43 AM
WestKyOnXFire's Avatar
I am having more or less the same problem as you, just started this morning. Battery on mine is fine, changed it two weeks ago. I turn the car on, hit the radio power button, and "Chrysler" shows on the screen. Thats it, no sound, nothing. The only difference between us is mine doesn't flash, it just comes on and stays on.
Old Apr 17, 2012 | 12:07 PM
PNA's Avatar
PNA
I've had this happen on a number of different occassions. Usually turning off the engine, taking the key out, re-inserting the key and then starting the car up -- fixes it for me.
Also, when / if you get it working, use the OPT button and scroll through its functions several times and get it back to when the radio function on the LCD screen appear. I've found it could be stuck in some weird non-radio function status as well.
Good luck.
Old Apr 19, 2012 | 08:47 PM
Good luck.
Thanks for the help PNA, I tried that and it worked. apparently I should just never turn the radio off via pushing the button lol
Old Apr 23, 2012 | 07:37 PM
martylogs's Avatar
Mine will not respond to any pushed button. Cd plays at very high volume and volume will not work. When cd removed, radio plays at very high volume and in between stations...nasty ugly....help
Old Apr 24, 2012 | 07:18 AM
PNA's Avatar
PNA
Sounds like yours is fried. Sounds like a new unit is in your future............
Old Jan 21, 2014 | 10:11 AM
B1gfun's Avatar
Did any one get a resolution? Mine was stuck in the "chrysler" mode too. I pulled the #8 and left it out for a few minutes and it seems to be fixed. I just hope it not a temporary fix.
Old Jan 21, 2014 | 10:28 AM
Try this ........
Old Jan 21, 2014 | 10:44 AM
B1gfun's Avatar
Thanks 180! if it happens again I will try this method. Thus far the pulling the #8 fuse seemed to be the fix. If anything happens again I will update back thanks!
usprb1976
Apr 4, 2024 04:57 PM
nataliefs
Oct 5, 2015 01:03 PM
bbsrt6
Sep 19, 2015 11:21 AM
skeet370
29
Sep 18, 2015 05:53 AM
rdougc
Sep 5, 2015 10:30 PM
