Where to get bigger Injectors?
Old May 23, 2012 | 12:17 AM
reiji's Avatar
Default Where to get bigger Injectors?
Hi all.
I read through many old threads but wasn't able to find any current information on where I can get a hold of some larger injectors for my NA.
Or is it even worth it in most cases?
I currently have a Intake, Exhaust and Eurocharged tune. I'm looking to get a 74mm throttle body and big injectors, then get a re-tune.
Where can I still find these now that TVT is gone?
Old May 23, 2012 | 01:05 AM
JHM2K's Avatar
Default Re: Where to get bigger Injectors?
When I had my N/A, I was determined I needed bigger injectors. But after seeing many people install larger ones and struggle with them, PLUS my 45 minute conversation with Rob from Needswings last year, I've conluded they're completely unnecessary. Tuning the car to like them at both idle and WOT proves to be the nightmare.
Honestly, you don't even need them on the SRT until you start throwing huge pulleys and tons of air...
In short, save your money.
Old May 23, 2012 | 01:08 AM
reiji's Avatar
That's just the advice I was looking for. I'll just stick to the throttle body in that case. Thanks!
Old May 23, 2012 | 01:13 AM
JHM2K's Avatar
Anytime.
74mm TB is a great mod... So is the bigger MAF, but whatever you do, reuse the OEM MAF sensor... install it in the bigger housing. Also, the 90° elbow has baffles that can be removed.
If you have the Needswings CAI, ignore my last sentence.
Old May 23, 2012 | 02:01 AM
rayth's Avatar
Can you clarify this point?
Old May 23, 2012 | 09:50 AM
JHM2K's Avatar
IIRC the NW CAI for the n/a motors replaces the full elbow up to the throttle body, and the MAF sensor plugs into the intake tube. This negates the need for a 74mm MAF as the NW CAI is already 3" (76.2mm-od) and since the 90° elbow is replaced with silicon, the baffles are by default "removed".
Old May 23, 2012 | 10:04 AM
xfireon20z's Avatar
you should only add bigger injectors on a n/a crossfire if you plan on getting a custom turbo setup or the begi kit or if your going with nitrous...
Old May 23, 2012 | 10:42 AM
sk8erjosh09's Avatar
Im not sure you would even need them then unless your running A Lotttt of boost or nitrous.....
Old May 23, 2012 | 11:18 AM
maybe this will help.
https://www.crossfireforum.org/forum...tors-sale.html
Old May 23, 2012 | 11:31 AM
witchal's Avatar
I have to differ on this one. I installed the larger injectors. It took a while for the car to like them but once it settle down I had a measurable mpg increase. Could I have had a bad stock injector? IDK but glad I changed them.
Old May 23, 2012 | 12:05 PM
xfireon20z's Avatar
im glad you saw a measureable amount in gas mileage improvement some people have reported that 2-3 miles a gallon improvement i think it's just too much of a headache cause of how each car seems to be erratic until it settles down after the bigger injector upgrade but most people want to add them for performance gains and it isnt gonna happen unless you have a bad injector or two on a n/a or like i said adding more forced induction or nos...
Old May 23, 2012 | 08:15 PM
32krazy!'s Avatar
you didnt get a mpg inc. your ecu is being fooled into thinking it is. do the research. unless your larger injectors were scaled to the 3.2 engine theres a good chance your actually washing down your cylinders with the excess fuel and potentially hurting your engine down the road.
amx the e55 injectors are the same size as the srt 480 cc . if you feel the need for larger injectors contact bruce at TUNING TECHNOLOGY MOTORSPORTS and order his fuel rail and 550 cc injectors
Old May 23, 2012 | 11:19 PM
rayth's Avatar
thanks for the clarification.. so the 74mm TB is still a good upgrade but no need to do anything with the actual MAF?
Old May 23, 2012 | 11:32 PM
I don;t need them well at least not at this time.
Old May 24, 2012 | 08:32 AM
ZAHANMA's Avatar
That makes sense. In terms of the 55k motor you aren't really modified to the point where others are seeing a need for more injector.
Old May 24, 2012 | 09:39 AM
JHM2K's Avatar
Correct, as long as you plan on running the Needswings CAI.
Old May 24, 2012 | 11:07 AM
32krazy!'s Avatar
the modded e55 engines that had the biggest issues were close to 500 rwhp and the # 8 cylinder was the lean cylinder to blow. the looped fuel rail and 550 cc injectors cured the issues. its the safest mod you can do to a modded engine
Old May 24, 2012 | 11:15 AM
JHM2K's Avatar
I know we've discussed this in person, but I wanted to ask this so someone else can see the answer if they were to ever search for it.
In your opinion, at what point is the looped rail necessary on the SRT motor? Stacked pulleys? Manis? A specific PSI of boost? Or is this simply a good "insurance" mod at any level of tuning?
Cheers,
Old May 24, 2012 | 11:59 AM
32krazy!'s Avatar
Cheers,
john the looped rail is safe insurance for any engine from mild to wild. the injectors can be reserved for the modded guys but they also flow more effiecently than the oem due to pencil point rather than wide spray pattern. i spoke to bruce before and he seemed open to a group buy for both or either if there was enough interest. as this is tested (on my car for over 6 months and the v8 cars for over a yr) and on more than 4 cars (v6) at this point its simple manufacturing lead times for him
Old May 24, 2012 | 12:09 PM
JHM2K's Avatar
Would he do this on a core/exchange program? Saftey is a good thing.
Also, if I recall, you dropped almost 2 points (AFR) just with the addition of the loop, correct? Or was that the loop plus injectors?
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
Sep 23, 2015 09:14 AM
04Fire
Sep 15, 2015 07:40 PM
