One push for rolling up windows
Old Jul 19, 2012 | 01:06 AM
J-Walk's Avatar
Default One push for rolling up windows
Is it possible to modify my coupe to be able to have the windows roll themselves up without holding the buttons? I've been spoiled by this new feature and I'd like it to work in both directions. (My old SRT was crank windows and manual locks to reduce weight)
Old Jul 19, 2012 | 08:18 AM
maxcichon's Avatar
Default Re: One push for rolling up windows
Rudy makes/made? a unit for one-touch roadster top deployment and one side benefit was one-touch windows. Search for a combination of those words?
Old Jul 19, 2012 | 08:40 AM
Smokin Red '06's Avatar
It's a SAFTY issue
Old Jul 19, 2012 | 09:12 AM
Originally Posted by Smokin Red '06
It's a SAFTY issue
No it's not. Most of my cars have this feature. In fact, the XF roadster has this feature using the top button. If you press it twice both windows come up automatically.
Old Jul 19, 2012 | 10:13 AM
arejohn's Avatar
I believe it is a safety issue. Approved one touch up requires a load sensitive return to open to prevent injuries. \7
Old Jul 19, 2012 | 12:54 PM
What FP said below, you don't need Rudy's auto-switch for this feature.
Mine works just fine .......
Old Jul 19, 2012 | 03:42 PM
rcompart's Avatar
In a roadster without the Quick Touch Top, you have to tap the button twice, holding it the second time, in one with the Quick Touch Top, you just have to tap it twice. Neither can be said for the coupes though... something about missing a button in the center console or something.
Old Jul 19, 2012 | 04:09 PM
J-Walk's Avatar
That's where I got the idea and I was wondering if the idea could be applied to coupes. Make it so the window switch can do the auto feature in both directions. I would undertake the project myself but I don't know enough about power windows to start the project.
I personally don't see how it's a safety issue. I've never seen someone leave their hand on the glass long enough for it to close on them. Everyone has that "hot stove" reaction. But if it did happen, well, I'm doing the world a little service.
Old Jul 20, 2012 | 11:42 AM
a7x6kse6's Avatar
Amazon.com: Install Essentials 530T Window Automation System: Car Electronics Amazon.com: Install Essentials 530T Window Automation System: Car Electronics
What about this?
Old Jul 20, 2012 | 12:24 PM
arejohn's Avatar
From 530T instruction. Notice the force (current) limiting resistors. No indication that a reverse will occur or that the window will stop but pressure is controled. I will have to check the volvo.
The 530T uses internal resistors to change the amount of force required to drive the window motors. These resistors
are controlled by a group of dipswitches on the side of the module. Some vehicles use very efficient motors
and little force is needed. This would require the switches to be set to a low setting. Some newer imports, such
as Honda Accords and Civics, may require a lower setting. Others use very inefficient motors, or the windows seem
“harder” to roll up. Some examples would be older domestic cars, as well as many full-size pickups. These vehicles
require the switches to be set to a higher setting.
Switches
Old Jul 20, 2012 | 02:24 PM
maxcichon's Avatar
You're right guys-my bad. You too, Rudy! I still like that thing you made.
Just wish it made margarita's, though...
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
smokey847
Nov 12, 2015 11:54 PM
cjw
Oct 26, 2015 10:26 PM
cjw
Sep 27, 2015 10:22 AM
