Electric Engine Fan running constantly when parked!
Old Aug 1, 2004 | 01:02 PM
scotth_uk's Avatar
Default Electric Engine Fan running constantly when parked!
Hi,
Anyone has a problem with the electric thermo fan staying on for a long time after the car has been switched off? I parked the car last night about 10pm and this morning at 10am the fan was still running.
Checked with an MB technical representative, and this is a known problem in some cars where the control module is affected by moisture, due to it's location within the bumper. Doesn't look like the xfire has the unit located there, so not sure if it is the same issue.
It's going to send my battery flat! Argh!
I tried disconnecting the fan at the first available connector, and reseating it, which made no difference. Fan started again as soon as I reconnected it. Cable runs over to what looks like a control unit, which is bone dry.
Help! Going to call the dealer tomorrow.
Old Aug 2, 2004 | 04:28 AM
english_bob's Avatar
Default
Scott,
There is a mechanism where the fan stays on to keep the heater on. I don't know whether you have accidentally activitated it.
Check out the operation in the Owners manual.
Otherwise, it sounds like you have a fault.
Old Aug 2, 2004 | 09:31 AM
scotth_uk's Avatar
Default
Checked that. Made sure it was disabled. Still no change, although today is sunny and dry so let's see if the problem goes away.
Old Aug 2, 2004 | 10:36 AM
Default
I will have a look in the 3000 page Manual tonight and see if there is an entry for this.
Old Aug 2, 2004 | 03:54 PM
Default
Scott,
The Operating Manual has a section on this 7.6. The reasons for the fan staying on are:
RADIATOR FAN CONTROL CIRCUIT SHORTED TO GROUND
RADIATOR FAN CONTROL MODULE
A/C SWITCH CIRCUIT MALFUNCTION
POWERTRAIN CONTROL MODULE
I couldn't find a way to get the stuff/diagrams out of PDF easily.
I think Saldous has managed to post the details somewhere on the forum. Drop him a PM. If he hasn't he can send you a copy of the manual on CD.
If you let me have your address, I can always post you a copy, or if you are near Staines, then you can pick one up.
Old Aug 2, 2004 | 05:08 PM
scotth_uk's Avatar
Default
Thanks Bob!
I really appreciate your effort to help me find out about it. Spoke with Lancaster's today and they are concerned and advised me to get to a DC dealer ASAP to have the disagnostics module connected for tests.
Will try to get back to Lancasters (or another dealer in Romford) for it this week.
Parked today at 4:30pm, and the fan was still running (and squeaking!) at 10:00pm. Turned the car on, then off, then to acc, then off and the fan stopped.
Weird.
Old Aug 2, 2004 | 05:21 PM
lordpercy's Avatar
Default
word of caution I've ha d abit of greif with the romford delaer in the past, I'd try and get it back to toby at Lancasters, hope you get it sorted.
Old Aug 2, 2004 | 05:27 PM
scotth_uk's Avatar
Default
Thanks for the tip on the Romford dealer. Looks like I'll drive the extra miles and take it back to the boys at Lancasters. They've been excellent over the phone so far.
Old Aug 5, 2004 | 01:49 AM
scotth_uk's Avatar
Default
Back to the dealer today:
1. Fan won't turn off, and it's squeaky.
2. Car has jumped out of gear 3 times.
3. Stereo locked up on me and had to pull the fuse.
4. Clutch throwout bearing is noisy
Old Aug 5, 2004 | 12:33 PM
scotth_uk's Avatar
Default
Fan control unit replaced on the spot - problem gone
Car is not from the affected batch, asked DC for advice, likely perform the TSB work.
Some CDRs cause the unit to boot wrong, likely cause. Fair enough.
Will be replaced when the gearbox work is done.
Old Aug 5, 2004 | 12:36 PM
Default
At least the Fan Fault was correctly included in the XF Manual.
Mine has jumped out of gear a few times but not in the last 1000 miles. My XF was not in the affected batch - would be keen to hear what DC say about your problem.
Old Aug 5, 2004 | 02:13 PM
saldous's Avatar
Default
See the following for screenshots from the manual:
(sorry quality isn't that great)
http://homepages.nildram.co.uk/~sald...ng/cooling.htm
Old Aug 5, 2004 | 04:41 PM
Guest
Guest
Posts: n/a
Default
I had the stereo lockup on me too, with CDR's in use. I just turned the ignition off and on, and it worked ok.
Old Aug 5, 2004 | 06:35 PM
RGT's Avatar
RGT
Default
My CF tech told me he has replaced several "freaked out" radios, so he installed a new one for me, "before you have any problems."
I think I must have the best dealer and service tech on the planet, they treat me like I'm Mr. daimler/Chrysler!
Matt
jgreen
106
Sep 18, 2017 11:46 PM
BrenLW
Aug 5, 2015 04:53 AM
waldig
Jul 15, 2015 02:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
