Subwoofer repair/replace...
Old Jan 19, 2013 | 06:23 PM
lildaddym's Avatar
Default Subwoofer repair/replace...
I need to repair/replace one of the subs in our roadster... anyone have a pictorial on that process? I have a buzz in the passenger side speaker, and I might try to fix it...
Old Feb 5, 2013 | 03:19 PM
autumnmass's Avatar
Default Re: Subwoofer repair/replace...
Did you get rid of the buzz, I have one coming behind the driver's seat speaker. Is it an easy fix. Thanks
Old Feb 5, 2013 | 03:38 PM
lildaddym's Avatar
The buzz is totally gone! The fix just takes some patience...not necessarily easy, but patience works. Find you a disposable camel brush, about 1/2 inch wide...cover the split in the foam with rubber cement applied by the brush. If the tear is long or goes across the foam, take a sheet of tissue paper and cover the tear after you apply the rubber cement, then put a layer on top. if at all possible, put rubber cement on the _back_ side of the foam, as well. Let dry for a few hours before pumping any sound through it. It's been a few weeks for me and I've had no problems. I am sorry I didn't take any photos when I did mine!
Old Feb 6, 2013 | 06:43 AM
autumnmass's Avatar
Awesome, thanks again for the writeup.
Old Feb 6, 2013 | 11:32 AM
lildaddym's Avatar
Careful when putting those subs back in, because you can bump it and it will come off....I lost a stud and had to order another.
Old Mar 19, 2013 | 10:19 PM
lildaddym's Avatar
UPDATE: More than a month down the road, tunes still sounding great!
Old Mar 25, 2013 | 05:31 AM
Thermor's Avatar
UPDATE: More than a month down the road, tunes still speakers sounding great!
I need to install front end speakers of my ford car, can you give some useful tips. Thanks in advance.
Old Mar 26, 2013 | 01:40 AM
lildaddym's Avatar
Can't help with Ford speakers...
Old Feb 15, 2014 | 07:00 PM
hokkabaz's Avatar
[QU=autumnmass;722781]Awesome, thanks again for the writeup.
******[/QUOTE]
I did take some pictures, will open a tread tonight. I am testing the speaker right now. I just wanted to try it out first, before giving any advice to somebody else
Subwoofer sounds as good as new and had been on for about 6 hours continuously right now.
Old Feb 23, 2014 | 08:52 PM
hokkabaz's Avatar
Get an old speaker( same diameter as the subwoofer, I think it is 6" or 6.5) and peel off the spongy part slowly, using your nails...(takes about 10 minutes.)
Get a bottle of Rubber Cement from Hobby Lobby ($2.99)
rip off the broken one from the subwoofer and replace it with the new one.
wait for an hour or two and it is ready to go...
subwoofer sounds as good as a new one.
usprb1976
Apr 4, 2024 04:57 PM
pioneer4x4
Mar 18, 2021 02:17 PM
HOT FIYA
Aug 12, 2015 03:46 PM
rmcdaniel12
Aug 6, 2015 07:17 PM
mobilefitt
Jul 28, 2015 03:45 PM
