radio removal... what to stick in those slots
Old Aug 25, 2004 | 10:57 PM
former NXMX5's Avatar
Default radio removal... what to stick in those slots
ive been all over and i cant find a shop that has a removal tool to work on te radio. I did however do a search on here and found out that becker sells the tool.
Regardless of that, whats involved in removing the radio? What does the tool do in that slot... push something up, down, to the left, acts as a hook, etc. It would really help if i knew what i was trying to accomplish before i stick anything else in there and ruin something. in the meantime i wwill call becker and wait for the mail
Old Aug 26, 2004 | 12:35 AM
Ron H's Avatar
Default
Why wait for a call back from Becker? Crutchfield sells the tools (www.crutchfield.com). They're the standard tools for European cars.
Old Aug 26, 2004 | 12:50 AM
David Burns's Avatar
Default Re: radio removal... what to stick in those slots
There are instructions in one of threads on where to find a web page that tells how to build your own tools. Other than that, I don't know what those tools do. I have seen others suggest "just go to any store that installs stereos" and they should have the tools, apparently many Euro cars use the same tools.
Old Aug 26, 2004 | 01:16 AM
Ron H's Avatar
Default
Crutchfield lists the tools as "Universal OEM DIN Radio Removal Tools," item #120869001, cost $9.99. The kit includes two tools. While not the cheapest, I've always received excellent service from Crutchfield.
Old Aug 26, 2004 | 07:19 AM
Default
thank you for the part number. i called crutchfield yesterday (after visiting an audio shop) and the guy ust about dint have a clue. he just said 'well its not in our database; i cant help you' doh.
Old Aug 26, 2004 | 07:30 AM
saldous's Avatar
Default
I got this set from eBay and it did the trick:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=5705983689
Old Aug 26, 2004 | 08:37 AM
sandmanqm's Avatar
Default
NXMX5,
I had my radio replaced with an Alpine CDA-9820XM and I watched the guy pull the "Infinity" stereo out.
He used two nail clipper files, the little blade that folds out, and pushed in toward the center of the radio. Out the radio came!
Now this guy has installed 1000s of radios in MBs and other European cars, so he may know the secret hand shake on how to pull the Becker radios out of the Crossfire.
I still have the OEM radio at home, but I dont' remember anything near the metal clips. Behind the face plate, the radio is like any other, a metal sleeve that encases the radio.
Good Luck!!!
Chris
Old Aug 26, 2004 | 09:02 AM
Sandman's Avatar
Default Radio Slot in Crossfire
The crossfire has the two slots in the radio as most Mercedes Becker radios. The key simply unlocks the two clamps holding the radio in.
If anyone goes to an audio shop that has no clue.....Run to a different audio shop, no rocket science there.
As for the post above EXCELLENT radio choice in the CDA-9820XM.
Matches the dash and provides am/fm/cd/& xm radio built in. THe X Micro antenna is sold seperatly but that unit is a great bang for the buck.
Regards,
Old Aug 26, 2004 | 09:07 AM
saldous's Avatar
Default
Just be careful if you are going to use something other than the appropriate tool to remove the radio. The clips inside those slots are weak and can break easily. My dealer said their own XFire tech had broken some himself. I trued initially by cutting an old credit card up to the size of the slots, it didn't work.
Old Aug 26, 2004 | 07:09 PM
Default
DID IT. what i did was break a pair of tweezers in half. then stick the tweezer into the slot, hugging the 'outisde' wall of the radio. once the tweezer stops, you have to push it horizontally towards the door. you might hear a metallic clicnk. thats the clip. its a pain in the @$$ to hold the clip and pull the unit out, so i had a friend help. one worked the tweezer while the other pulled out the unit. yes i could have ordered crutchfield part number 120869001, but im just not that patient i really wanted this radio in this weekend.
thanks for all the help --
Old Aug 28, 2004 | 01:13 PM
X-fired's Avatar
Default
Dealer also has the tool. I had my dealer pop mine out without any hassles.
Old Sep 6, 2004 | 10:40 AM
Default
Hey Chris...
Man, wish I could have got a better look at that Alpine unit last weekend. The feature set looks just like what I'm seeking. Several reviews have complained about the dim display, how's it seem to you? If only this unit did MP3...
I'm heading out of town (Groton, CT) for about 10 days, are you busy the weekend of the 18th? I could meet you somewhere for lunch or something (not Burger King )and get a closer look? I'll buy!
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
brandoni
Sep 30, 2015 07:48 PM
leaddog2015
Sep 26, 2015 08:23 PM
Selbyl
Sep 26, 2015 04:15 AM
