Intercooler or Chargecooler
Old Feb 20, 2013 | 01:47 PM
blackpepper's Avatar
Default Intercooler or Chargecooler
I parked my srt up a little to far on a high curb and heard the awfull scrapping sound so i slowly backed up and parked.While inspecting my minor scraps thats some wet sanding and touchup will cure I was losing coolant liker crazy,I dropped the engine cover at the cover with the car on ramps and notice coolant is pouring from my I suspect this is the intercooler,well I much am I in for and is it a DIY task.
Old Feb 20, 2013 | 01:54 PM
grip grip's Avatar
Default Re: Intercooler or Chargecooler
Sounds like you damaged the Heat Exchanger or Radiator, as the intercooler (charge air cooler) is underneath the supercharger and safe from your lack of driving skills.
The heat exchanger is cheap ($50 - used) and an easy swap. The radiator is more of a pain to swap, and not nearly as cheap.
Old Feb 20, 2013 | 03:14 PM
I found one by a company called PLM anyone have one its suppose to be a upgrade for our cars only 325$,I still dont how to remove it except almost removing the front clip or I am still looking thru some pissed eyes on how I did a dumb park dang.
Old Feb 20, 2013 | 03:42 PM
waldig's Avatar
Talking Re: Intercooler or Chargecooler
You need t get under it to change. If the radiator is not going down you did the HE only. IF they are not separated youll not know for sure till u look.
If you dont have a lift you can park on the yard with the front wheels at the curb and with the parking brake set go under to see with the safe 9" lift helping - be safe about it.....
The he is first, the radiator is above the frame support but you can push stuff back to hit the radiator, gotta see, take your camera and let us see, if you wish.
Best luck, woody Hope you snagged a hose or something stupid like that.
Old Feb 20, 2013 | 10:20 PM
grip grip's Avatar
If you need a heat exchanger, there is one over on MBWorld for $50 plus shipping. It is larger than stock (came off a supercharged V8), so it's a cheap upgrade.
OEM E55 Heat Exchanger - MBWorld.org Forums
Old Feb 21, 2013 | 12:33 AM
I have a New Factory unit made for the crossfire srt6, that i put on my car to drive two blocks,, now it is used, i guess,, got it from the dealer but i will take 100 + shipping
I am in South Florida. jim
Old Feb 21, 2013 | 02:26 AM
dinasrt's Avatar
I can offer you the same deal, only my 55 H/E has less than 20k miles on it. Bear in mind that the upgrade is not plug and play. You'll need minor fabricating skills for the install. Not real difficult though. Let me know.
Old Feb 21, 2013 | 07:27 AM
Default
Whats actually required to make it wrk because I am bypassing my heat exchanger and taking it to a local performance shop to do the install,just got out the hospital with pneumonia not in the mood yet to be wrking on my 6
Old Feb 21, 2013 | 10:56 AM
Yes its the heat exchanger got the car up on ramps and belly pan off,just going with the PLM upgrade direct bolt in much better than stock.Its a highly modded car,its xblake old car mods are code3 pulley, inmotion can tune,needwings single,needwings ported manis,oil catch can.Now this is off topic but I respect any answer the car makes 348hp and 364tq at the wheels,why do car with the 61mm pulley make less or a hair more power,as bad as I want a 6imm pully it dont appear worth it.Xfireblake videos are on youtube and the video is proof,and I think the car is actually pushing 18lbs of boost,he did remove the gauge before selling the car,plus the car did a 7.88@90mph on street tires last month with a 1.8 60ft no brake torqing.
Old Feb 21, 2013 | 11:05 AM
dinasrt's Avatar
Originally Posted by blackpepper
Whats actually required to make it work because I am bypassing my heat exchanger and taking it to a local performance shop to do the install,just got out the hospital with pneumonia not in the mood yet to be wrking on my 6
Our stock H/E's have brackets that allow it to be fastened, and don't line up or work w/ the E55 or aftermarket units. The E55 exchanger is 5 or 6" longer, and thicker also. I had to trim off some of the plastic mount tabs for a proper fit, and used a couple heavy duty HVAC black zip ties. It would be impossible for me to try and type out a how-to. Your performance shop should be able to handle it fine. Make sure they pad any metal to metal contact areas.
Old Feb 21, 2013 | 11:19 AM
dinasrt's Avatar
My understanding is that the PLM's are China? A Super Cooler, or EC exchanger would perform much better. And as I mentioned, the PLM(or any others) will not just bolt up. The EC unit is made by C&R racing (USA), and makes exchangers for some of the NASCAR teams as I understand it. Regarding the damage to your stock exchanger; did you crack one of the plastic end tanks?
Old Feb 21, 2013 | 12:15 PM
pm me your adress and
I may be taking you up on that deal with the E55 he
Old Feb 21, 2013 | 07:23 PM
dinasrt's Avatar
Just PM me when you decide. No problem.
Old Feb 22, 2013 | 01:47 PM
Ordered the PLM unit and on there page as well as speaking with a sales rep its a direct bolt on for our cars and have a lifetime warranty,also I just read its not a direct fit for the slk due to the tow hook in the way.We have the car up and yes the left side endtank was cracked if you are facing the car.
Old Feb 22, 2013 | 11:34 PM
dinasrt's Avatar
Cool. Let us know how the install goes, and your improvement w/ intake temp.'s.
Old Feb 23, 2013 | 09:08 AM
grip grip's Avatar
If PLM is s direct bolt on, then they all are. The PLM is larger than stock so it's impossible for it yo go on without modifications to the car.
Old Feb 24, 2013 | 05:04 AM
32krazy!'s Avatar
i probably have a oem h/e for a slk32 in my shed if you want me to look for it. the plm will not bolt on without tweaking
Old Feb 24, 2013 | 07:54 AM
I already ordered the PLM should get it weds thanks anyway,I wanted something a little better than stock anyway since the car is modded.
Old Feb 28, 2013 | 03:15 PM
The installed pretty much straight forward we took the car out and measured the iat with a scan tool and at 140 mph for 15 seconds it never topped 100 degrees and cruising around its always about 10 degrees above the temp outside and we checked the timing we saw about 26 degrees at wot throttle with zero knock whatever that mean,the guy who did the install said the car had a aggressive but really safe tune,i still cant get the pics i have took posted i admit i am no good at the stuff sorry
Old Feb 28, 2013 | 03:23 PM
grip grip's Avatar
No offense, but from what I've seen over the part two years I have to call BS (for lack of a better term) on your "never topped 100 degrees". Sorry, but there is no way you're only seeing 100 degrees unless you have a remote ice box, killer chiller, etc. Maybe you meant 100 Celsius, as that I'd believe.
I'm not trying to bust your *****, I'm just letting you know that's a pretty outlandish claim.
