Alarm Problems
Old May 6, 2013 | 08:10 AM
D&NIS's Avatar
Default Alarm Problems
Hi everyone,
Since a few days i have some problems with my alarm.
First time a Chime(not the alarm) went off under the hood and the alarm stopped working.
I disconnected the battery waited about 5min and the beeping stopped.
Connected everything and problem looked fixed.
2 days later my alarm goes off without any reason. when i unlock the door and re-lock the problem seems to fix itself.
Now my alarm goes off every now en then, about 1 time every 2 days.
Would it help me to change the battery (It still could be the original its a Varta) Although i tested it a few week back and it seemed to be good.
Or could it be a door contact??
Please help me out here, or redirect me to a threat that might help.
Thanks!
(Its about a 2004 Limited Coupe)
Old May 6, 2013 | 08:21 AM
Default Re: Alarm Problems
Originally Posted by D&NIS
Hi everyone,
Thanks!
If as you say it's a 2004 and you think the OEM battery is still in it, I would certainly start by replacing the battery .....
Old May 6, 2013 | 10:59 AM
D&NIS's Avatar
Thx!
I'll start with ordering the battery.
This should be the one:
VARTA 574012068 C4 BLUE dynamic E11 12V 74Ah(20h) Start / Licht accu batterij - Advitek Marine Systems A.M.S. B.V.
Old May 18, 2013 | 06:53 AM
D&NIS's Avatar
Bought new battery, alarm just went off again :S
Old May 18, 2013 | 06:44 PM
You were living on borrowed time with that battery anyway. It could have gone when you were least expecting it and caused a lot of trouble.
I have no ideas on your problems, but do you have water in the trunk at all?
It could be an alarm problem itself though.
Or a switch somewhere.
Old May 19, 2013 | 08:20 AM
One thing we need to remember when responding to posts regarding Varta batteries :
Here in the states or Canada, a Varta is 99% sure to be an OEM original battery, in Europe, that is not always the case. You can buy NEW Varta batteries there.
Old May 20, 2013 | 06:05 PM
D&NIS's Avatar
Youre right, battery lived long enough for 9 years. I'll check to see if there's any water in the trunk.
Past few time's i sometimes trigger the alarm by unlocking the doors (not the actual alarm but a beep.. beep. beep. sound).
There's a battery in the Alarm-module does it have to be replaced sometime?
Anyway i'll try so things out, hoping to find the problem.
If there's an easy way to just kill the whole alarm it would work as well for me.
Old May 20, 2013 | 06:07 PM
D&NIS's Avatar
I'm pretty sure this one was the original because it had the Mopar and Chysler sticker on it. I bought a Varta back indeed, not hard to find here.
Old May 20, 2013 | 06:13 PM
Today this was posted by a person who was not afraid to use a can opener.
Fix that alarm siren battery
Old May 20, 2013 | 06:20 PM
D&NIS's Avatar
Thx! now i know what part i maybe need to order..
Will check the trunk tomorrow should be an easy acces cause i sawed the foam in 4 pieces when i needed to reconnect a hose/wire for the central unlocking.
The alarm module is where the Airpump is right?
Old May 20, 2013 | 06:25 PM
No.....
Its under the cowl.
See this PDF to see how to remove the cowl.
Old May 20, 2013 | 06:37 PM
D&NIS's Avatar
No.....
Its under the cowl.
Thx!, but i wonder why water in the trunk would cause the alarm if its not located there.
Strange in the Quote option i can see you the PDF link but it doesnt show on the forum.
Old May 20, 2013 | 06:57 PM
https://www.crossfireforum.org/forum...tml#post740496
tcar32909
Aug 1, 2024 02:41 PM
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
Den656
Sep 23, 2015 12:27 PM
skeet370
29
Sep 18, 2015 05:53 AM
