Changing Door Speakers
Old May 21, 2013 | 10:33 PM
SrWilliams's Avatar
Default Changing Door Speakers
Alright, several months ago I changed the tweeters in both doors and successfully removed door panels, etc.
Now I realize that the large speakers in the bottom part of the door are blown. Do I have to remove the entire door panel to change those speakers as well, or can the grill be removed thereby exposing the speaker.
I sure don't want to go thru removing panels all over again.
Also, can someone tell me the size of the door speakers (not tweeters) I want to get some aftermarket replacements and I need to know the size
Thanks
Old Jul 30, 2013 | 07:49 PM
FabianMoody's Avatar
Default Re: Changing Door Speakers
Hey do you have the factory speaker trim? the one on my left side fell off?
Old Jul 30, 2013 | 11:11 PM
Abaton6's Avatar
These guys say 5 1/4", or 6 1/2. Looks like the smaller ones need a bracket to fit.
Car Selector
Old Jul 31, 2013 | 10:07 AM
Infinity's Avatar
Door speaker is a 6.5"
If you are using the factory amp then look for speaker systems with an impedance around 2ohms to ensure you maintain power output levels (factory setup is a 2ohm setup, normal aftermarket sits at 4ohms) Infinity and JBL products in the reference and gto lines drop right in and have the same screw hole locations and meet the 2ohm criteria
Old Jun 29, 2021 | 08:05 AM
jxrgxn's Avatar
Hi,
Did you ever get a respons on your request of removing the speaker grill without removing the door panels? My RH speaker is blown and I have to replace it. The door cover is guit an operations.
Thanks
PNA
Nov 12, 2020 04:44 PM
JCassiW
Southeast Forum
20
Mar 3, 2019 09:43 AM
xfClifford
Aug 3, 2015 11:03 PM
pioneer4x4
Jul 27, 2015 02:04 PM
66L72M21
Jul 15, 2015 04:23 PM
