problem with 2 gear and the gearbox freeze
Old May 30, 2013 | 07:46 AM
prdec's Avatar
Wink problem with 2 gear and the gearbox freeze
Hello!
i have chrysler crossfire 05 AUTOMATIC 3,2 V6
when i drive with slow pace and then i press the gas pedal harder for more power the gearbox first shift the gear down OK, but then ( when i let the pedal) the gearbox dont switch the gear up smoothly or somethimes the gearbox "freeze" dont switch the gear and I stay with no power. If this happens I must immediately stop the car and get the key off from ignition to reset.
If anybody knows how bad is this problem and how can I repair it, please write me here.
Thanks!
Old May 30, 2013 | 09:10 AM
robby363's Avatar
Default Re: problem with 2 gear and the gearbox freeze
Low fluid level is the #1 cause of the problem you described.
Old May 30, 2013 | 09:48 AM
prdec's Avatar
how is ths possible..... In previous 2 years i was changing oil 2 times in the gearbox. Every time when the oil was changed the gearbox was doing good. Then a few months later, the gearbox was not changing gears smoth.
Is maybi problem with oil because i dont know if the mechanik give me te original oil in. ( I wanted the original one becasu it must be in gearbox).
Old May 30, 2013 | 04:07 PM
robby363's Avatar
Have you checked to see if the electrical connector plug is leaking? It's a common problem on the transmission.https://www.crossfireforum.org/forum...-ta-daaaa.html
pioneer4x4
Mar 18, 2021 02:17 PM
nataliefs
Oct 5, 2015 01:03 PM
bbsrt6
Sep 19, 2015 11:21 AM
skeet370
29
Sep 18, 2015 05:53 AM
rdougc
Sep 5, 2015 10:30 PM
