For those of you who have an Ultragauge, Scangauge, or use Torque...
Old Jun 6, 2013 | 11:05 PM
lildaddym's Avatar
Default For those of you who have an Ultragauge, Scangauge, or use Torque...
Have you noticed that the OBDII disconnects at random times? I noticed it today with my phone that's running Torque. The software actually had to re-establish a connection with the Bluetooth OBDII module, and go through all of the protocols before it worked again. Noticed that my Ultragauge would occasionally blank out, and the mileage would be off after that...
Old Jun 7, 2013 | 07:38 AM
Mrmiata's Avatar
Default Re: For those of you who have an Ultragauge, Scangauge, or use Torque...
Hmm... might be your adapter? Never seen it happen with mine. (Running Torque)
Old Jun 7, 2013 | 08:50 AM
My UltraGauge sometime does the 'hiccup', but the readings always come back the same .....
Old Jun 7, 2013 | 08:53 AM
Same here, they all come back in a few seconds. Never questioned it, just thought, "Oh, well..."
Old Jun 7, 2013 | 10:51 AM
rayth's Avatar
I don't think I've ever noticed my Torque Pro disconnect
Old Jun 7, 2013 | 02:40 PM
waldig's Avatar
Talking Re: For those of you who have an Ultragauge, Scangauge, or use Torque...
Governmental tapping of the wireless device?? Woody
FRIDAY
Weekend yeaaaaah
Old Jun 7, 2013 | 03:00 PM
Mrmiata's Avatar
FRIDAY
Weekend yeaaaaah
Ahh.. guess you heard about Verizon too...
I'd check for helicopters shortly after it drops out.. maybe find a tunnel to park in.. turn off cel phone.. etc.
Old Jun 7, 2013 | 05:24 PM
Selbyl's Avatar
The only time I've had this happen on Torque Pro is when turning the car from on to start.
Old Jun 7, 2013 | 06:33 PM
rmaier's Avatar
Never any issues with the scan gauge on the Black 1 or the torque pro on the blue 1 and both are fine no problems. Check your pin out on the odbII
Old Jun 7, 2013 | 11:40 PM
lildaddym's Avatar
It's happened with both of my tools, the ultragauge and the bluetooth OBDII...takes a minute for the connection to recover.
Old Jun 7, 2013 | 11:42 PM
lildaddym's Avatar
How would I check the pin-out?
Old Jun 8, 2013 | 01:52 AM
rmaier's Avatar
Look at the connectors on the ODBII socket under the dash and specifically look for corrosion or verdigress on the copper. The best way to clean those is a tuner or electrical spray cleaner that can be had from Radio Shack or a simple pencil eraser works as well. The common denomator here would be the socket and not the devices.
Old Jun 8, 2013 | 02:22 AM
lildaddym's Avatar
I concur, sir...that was my initial thought. I will see what I can do. Thanks for the tip!
a7x6kse6
Apr 19, 2015 03:41 PM
crookedview
Jul 11, 2011 05:16 PM
jturkel
21
Jun 30, 2010 01:16 AM
dinasrt
Jun 29, 2010 03:00 PM
crossfire2006
Feb 9, 2010 08:03 PM
