P0410 - How to fix it for those who have fixed it already
Old Jul 9, 2013 | 06:18 PM
nickwe21's Avatar
Default P0410 - How to fix it for those who have fixed it already
Hey guys!
Read up some on this error code. It seems to come and go but doesn't affect operation of the car all. I found this thread: "How to Repair Relay Control Module (RCM) - (Mystery no Start)" on the forum but does this fix the problem??
Also, the thread talks about a no start but my car starts just fine. Do I still solder at the same part as described in the instructions??
Thanks for all of you who have successfully dealt with this already and can shed some light on the problem!
Nick
Old Jul 9, 2013 | 09:24 PM
syfi's Avatar
Default Re: P0410 - How to fix it for those who have fixed it already
Hey Nick, I had the same prob. Check engine light came on and had the same eror code. Did the fix and all is good now. Link to my fix ....
https://www.crossfireforum.org/forum...tml#post744394
Old Jul 9, 2013 | 10:07 PM
turbomar's Avatar
Originally Posted by nickwe21
Hey guys!
Nick
First solder as per the thread instructions. If code p0410 persists however, you most likely have burned contacts of the air injection blower relay, 1 of the 5 relays in the RCM. At that point, Your best bet is to buy a good used or a new RCM
Old Jul 10, 2013 | 01:44 PM
nickwe21's Avatar
Ok thanks guys!
I'll try the soldering solution this weekend. Have a pretty good idea where the broken joint might be at. If that doesn't work I'll move on to the next step. Either way thanks for the helpful comments! I appreciate it...will report back when all is done..
Old Jul 10, 2013 | 07:35 PM
If the relay is burnt and you are good with a soldering iron you can replace the relay for about $2. The RCM will cost a lot more.
https://www.crossfireforum.org/forum...tml#post550548
fastfred
Nov 5, 2018 09:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
fastfred
Sep 24, 2015 03:05 PM
eatmycrackers
Sep 23, 2015 09:08 AM
Selbyl
Sep 22, 2015 10:41 PM
