Car Won't Start After Fixing "Sticky Ignition Switch" HELP!!!
Old Jul 11, 2013 | 02:30 PM
MXQB7's Avatar
Default Car Won't Start After Fixing "Sticky Ignition Switch" HELP!!!
My Car wont start!
its not even cranking the engine at all .
all the lights on the dash board come on and the alarm works
But the car doesn't make a sound when i try to turn it on!
i was searching and i found out that it might be this : attached -------------> How to Repair Relay Control Module (RCM) - (Mystery no Start)
but does this cause after fixing the ignition switch
is it a common issue
or was it my luck that it happen at the same time
PLEASE HELP!
Old Jul 11, 2013 | 02:39 PM
Default Re: Car Won't Start After Fixing "Sticky Ignition Switch" ! HELP!!!!
Originally Posted by MXQB7
My Car wont start!
PLEASE HELP!
There is the plug that is on the back of the ignition switch, did you put that back on, did it get damaged on some pins?
Also, there is the halo ring that goes around the ignition keyhole, is that on? The other end of the halo wire plugs into the SKREEM module if that has become damaged or unplugged the car will not start.
Someone forgot to put the halo back on a few years back, but I think it cranked but did not start.
Old Jul 11, 2013 | 04:16 PM
MXQB7's Avatar
Unhappy Re: Car Won't Start After Fixing "Sticky Ignition Switch" ! HELP!!!!
yes I did put the the wire from the back on!
the one thing I couldn't find was were the key hole ring goes.
The cable I mean of course is so small and skinny plug.
but cant remember or cant find the plug in entrance ?
but I would think that for the green light it has right? I don't think It would affect the cars
ignition .
Im very frustrated and just want the car to run...
if its not one thing its the other
Old Jul 11, 2013 | 06:30 PM
ignition .
That halo ring determines if the car has the correctly chipped key in the ignition.
So to put it simply.
No correct chip in the key in the ignition = no start.
No halo ring signal = no start.
Old Jul 11, 2013 | 06:41 PM
MXQB7's Avatar
Ok so I should hook up the halo ring to see if it turns green..
but I cant find were the other side of the cable goes into..
have u heard of other reasons y u think it wont turn on? even if the halo ring turns on!?
Old Jul 11, 2013 | 07:12 PM
Hook up the ring.
To put it simply.
The halo ring is a part of the anti-theft system.
If the car would start without the halo ring hooked up, a thief would only have to pull of the wire and drive away. OK?
Old Jul 11, 2013 | 09:05 PM
MXQB7's Avatar
Ok I completely understand by my thing is where ?
I detached the ring.
So the end of the cable is unplugged
I cannot find the place it goes, where to insert it ?
I've been looking under the steering wheel but cannot find it
Plz help ?
Old Jul 11, 2013 | 10:56 PM
Plz help ?
It is behind the radio under the dash pad.
If you look at these posts (click) the third or fourth one down asks for pictures of the SKREEM module and there are three pics of it in a post.
foxy1305
U.K.
Jan 1, 2020 11:41 AM
smmanley1996
Sep 4, 2015 04:40 PM
Keepmeinmind13
Jul 10, 2015 01:05 AM
ultrajim49
17
Jun 27, 2015 12:20 AM
carmax
Jun 18, 2015 01:30 PM
