Ignition Locked - New Cylinder Cost
Old Jul 26, 2013 | 11:42 AM
ssammons's Avatar
Default Ignition Locked - New Cylinder Cost
After describing the problem ( steering wheel, ignition & transmission locked), my mechanic advised that he probably needs to replace the cylinder on the ignition.
Any advice on cost expectations.
Can the transmission be unlocked so I can push the car back to be towed?
Old Jul 26, 2013 | 12:37 PM
rekcah's Avatar
Default Re: Ignition Locked - New Cylinder Cost
sounds like the sticky ignition problem. read the sticky ignition thread
https://www.crossfireforum.org/forum...tml#post681520
Old Jul 26, 2013 | 01:02 PM
ichon's Avatar
Slide the silver and black "RNDP" cover forward, find a small notch under the cover, push it with a screw driver and it will release the gear lock and allow you to put the car in neutral. The ignition solenoid should run about $800. Try to get it from a MB Dealership as opposed to Chrysler because they have them in stock. Chrysler has a mark up on that part. Labor is gonna cost ya a bit as well. Good luck.
P.S. The tow truck operator should know how to unlock the tranny. They do it all the time.
Old Jul 26, 2013 | 03:05 PM
The only thing you should replace is the mechanic. It sounds like the problem rekah describes above. Do not replace any part, fix what you have by removing the pin as outlined in the post and live happily ever after. Replace the part and it will eventually fail as well.
If you cannot do it get the mechanic to read the article and do it for you, it will cost no more than two hours work, more like one and a half hours labor.
Can you remove the key?
Old Jul 27, 2013 | 02:27 PM
jtaylortech3's Avatar
Listen to what onehundred80 and rekah said! Anything your mechanic or anyone else said is a load of rubbish, this is a HUGELY common issue on the Crossfire and I had the exact same problem few months ago!
I followed the steps on the thread that rekah posted and it worked perfect. Therefore problem solved!
Old Jul 27, 2013 | 10:46 PM
ssammons's Avatar
Is there any risk not having the spring and pin replaced?
Old Jul 27, 2013 | 10:51 PM
NO. This has been researched and most of us here have done the mod and all is well. Mine locked up two years ago, since then, I have put 50,000 miles on mine - no issues. I did the repair myself following the tutorial on this board - and I'm no mechanic.
Those who replace the assembly eventually go thru it all over again - it is a design flaw that was never addressed.
Do the mod as described and forget about it!
Old Jul 28, 2013 | 11:47 AM
What he said! Like i said it worked for all of us and its a proven solution.
Old Jul 31, 2013 | 09:00 PM
weckmanrl's Avatar
Smile Re: Ignition Locked - New Cylinder Cost
Had my mechanic follow the fix instructions recommended on this thread. $160 in labor to remove the pin/spring as instructed. Works fine now. Thanks for the advice.
Old Mar 14, 2017 | 10:12 PM
2ndtonone's Avatar
My 04 xfire justed locked up at the bank. Sat here for over 2hours waiting for a tow lol. Key will not turn and steering wheel is locked, key is removable but will not turn. It has been hard to turn on several occasions and it completely quit. I have read through the "sticky fix"can I just remove the one I have and take out the pin and spring? and all is good again or do I need to buy a new unit then mod it? If anyone has done the mod did you just pull the old unit and trash the spring and pin under the cover and back in buisness?
Old Mar 14, 2017 | 10:38 PM
Just fix the one in your car and you are good to go.
Old Mar 14, 2017 | 10:42 PM
2ndtonone's Avatar
thanks just what i needed. saving money!!!
fastfred
Nov 5, 2018 09:47 AM
Apr 28, 2016 02:04 AM
Selbyl
Sep 26, 2015 04:15 AM
fastfred
Sep 24, 2015 03:05 PM
