Ignition Locked - New Cylinder Cost
After describing the problem ( steering wheel, ignition & transmission locked), my mechanic advised that he probably needs to replace the cylinder on the ignition.
Any advice on cost expectations.
Can the transmission be unlocked so I can push the car back to be towed?
Re: Ignition Locked - New Cylinder Cost
sounds like the sticky ignition problem. read the sticky ignition thread
https://www.crossfireforum.org/forum...tml#post681520
P.S. The tow truck operator should know how to unlock the tranny. They do it all the time.
If you cannot do it get the mechanic to read the article and do it for you, it will cost no more than two hours work, more like one and a half hours labor.
Can you remove the key?
The only thing you should replace is the mechanic. It sounds like the problem rekah describes above. Do not replace any part, fix what you have by removing the pin as outlined in the post and live happily ever after. Replace the part and it will eventually fail as well.
I followed the steps on the thread that rekah posted and it worked perfect. Therefore problem solved!
on
NO. This has been researched and most of us here have done the mod and all is well. Mine locked up two years ago, since then, I have put 50,000 miles on mine - no issues. I did the repair myself following the tutorial on this board - and I'm no mechanic.
Those who replace the assembly eventually go thru it all over again - it is a design flaw that was never addressed.
Do the mod as described and forget about it!
My 04 xfire justed locked up at the bank. Sat here for over 2hours waiting for a tow lol. Key will not turn and steering wheel is locked, key is removable but will not turn. It has been hard to turn on several occasions and it completely quit. I have read through the "sticky fix"can I just remove the one I have and take out the pin and spring? and all is good again or do I need to buy a new unit then mod it? If anyone has done the mod did you just pull the old unit and trash the spring and pin under the cover and back in buisness?
Selbyl
09-26-2015 04:15 AM
