Crankshaft Position Sensor strikes again!
Old Oct 10, 2013 | 12:35 AM
gguillot's Avatar
Default Crankshaft Position Sensor strikes again!
The CPS in my '04 decided to go TU with absolutely no warning. At only 53k miles, I didn't really think it would go anytime soon, despite what I have read here on the forum.
Five minutes after leaving work, in rush hour traffic, the XF just quit as if the key had been shut off. It started again after 15 minutes, but I only got another 2 miles before it went out for good. Had to call the tow truck.
Anyway, the CPS is readily available - I found it on Amazon for $40 (Bosch OEM), so I ordered TWO - will keep one in the car as a spare. Followed the great replacement instructions in the Sticky. Easy 15 minute job.
One word of advice - you must get the 1/4" drive bit for the bolt on the CPS (exactly as it says in the sticky) - there is not enough clearance to fit a 3/8" drive socket (at least not on my engine.) Also, I had to lightly sand the shaft of the CPS to get it to fit into the very tight hole in the engine.
Keeping a spare CPS and socket wrench in the car from now on....
You have been forewarned.....again.....
Old Oct 10, 2013 | 09:05 AM
Default Re: Crankshaft Position Sensor strikes again!
One word of advice - you must get the 7/16 drive bit for the bolt on the CPS - there is not enough clearance to fit a 3/8 drive socket (at least not on my engine.) Also, I had to lightly sand the shaft of the CPS to get it to fit into the very tight hole in the engine.
Keeping a space CPS and socket wrench in the car from now on....
Re reading your post I think you may be referring to the size of the square drive. In that case I think you mean the 1/4" square socket and not 7/16".
Correct me if I'm wrong, I am wrong quite often and I will not get upset.
Last edited by onehundred80; Oct 10, 2013 at 09:15 AM. Reason: Re read post meaning
Old Oct 10, 2013 | 09:17 PM
gguillot's Avatar
You are right. I edited the post to state the 1/4" drive. Thanks.
Old Oct 10, 2013 | 09:27 PM
Mrmiata's Avatar
Funny how after 1 time you become a religious believer ..
Me included!
roar
Jun 15, 2022 11:46 AM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
RED DOG
Oct 5, 2015 07:59 PM
bobbie
Sep 12, 2015 12:49 PM
