Roadster Subwoofers
Old Oct 24, 2013 | 05:09 PM
Thornh's Avatar
Default Roadster Subwoofers
I know there are several threads on this subject but no real answers that I can use, so here is my question:
Can the subwoofer baskets be disassembled to the point that a factory replacement speaker only can be used in either the right or left location. I think we all are aware that there is a huge price difference between the left and right part numbers.
Since there seems to be no direct fit replacement available from the aftermarket, I am willing and ready to purchase 2 Right speakers to get the replacement of both left and right done...
Has anyone sucessfully done this?
Thanks,
Thornh
Old Oct 25, 2013 | 07:34 AM
jimmirehman's Avatar
Default Re: Roadster Subwoofers
Ive replaced both and from what i saw, the speakers are identical... I havent actually put a right on the left but it seems you would just unscrew the speaker from the basket and rotate it to fit the screw holes of the left basket.
perhaps someone else can chime in here, but i think they are literally the same speaker.
Old Oct 25, 2013 | 12:40 PM
Thornh's Avatar
That's pretty much what I am thinking, i guess i will order up 2 of the lefts, since they are affordable and hope I can take one apart and install it into the right side bracket
Thanks for the input!
Old Jan 12, 2014 | 11:20 AM
crcarch's Avatar
Where did you find the subwoofers? I can't seem to find a factory speaker anywhere as they are apparently discontinued.
Old Jan 12, 2014 | 11:25 AM
They are discontinued and impossible to find. I bought mine off another member on here. If you have a set you can send them off to be repaired. But other than that, salvage yard or eBay-esque sites are probably your best bet
Old Jan 12, 2014 | 12:02 PM
Thornh's Avatar
I could not find one either, although many parts sites list them when you go to place can order they are not available. I ended up replacing them with earthquake sws 6.5 subs with an aftermarket amp.
Old Jan 30, 2014 | 10:25 PM
jsquare's Avatar
I have to replace just one speaker. If someone buys a pair just to replace one speaker post here and i'll split the cost for the other speaker
Old Feb 28, 2014 | 10:46 PM
andyrouby's Avatar
Default
I replaced the foam ring from a same sized speaker with rubber cement . Sounds like nrw
LE Cross
Sep 14, 2015 01:20 PM
HOT FIYA
Aug 12, 2015 03:46 PM
rmcdaniel12
Aug 6, 2015 07:17 PM
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
