Deep transmission pan
Old Oct 24, 2013 | 05:18 PM
velociabstract's Avatar
Default Deep transmission pan
I've known about this pan for a while now. Some websites say it holds 3 additional quarts and one says 4. I looked under my car today and my exhaust hangs down lower than the pan would. I don't know if I'll actually buy one but I thought it might be of interest to someone on this forum. The owner of Speedlogix lists it as fitting the Crossfire. She should know as she owned a Crossfire once upon a time.
B&M NAG1 Deep Transmission Pan - 10300
Les
Old Oct 24, 2013 | 05:31 PM
Default Re: Deep transmission pan
The fluid level is measured from the bottom of the pan. You would have to figure out a new measurement before installing the pan.
Old Oct 24, 2013 | 05:36 PM
They thought of that. The dip stick bottoms on a tab or shelf they built into the pan so you use the same exact measurements as a stock pan.
Les
Old Oct 24, 2013 | 07:35 PM
I am not sure that is correct, I was a bit low once and got no reading on the stick when cold. I added a quarter of a pint and it went up a lot. I think it measures from a shelf somewhere under the stick tube.
Old Oct 24, 2013 | 09:29 PM
philosophico's Avatar
Unlike motor oil, its best to check the trans fluid when its warm and up to temp.
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
