Skip
Old Dec 8, 2013 | 03:18 PM
Bill1112's Avatar
Default Skip
Looking for some help. 2004, 76,000 mikes just started skipping pretty hard when I stop at a red light not every time about every 10th time or so put the car in natural mash the gas a couple of times she back to normal. Does anyone know the Fix. Thanks Bill
Old Dec 18, 2013 | 03:23 PM
Bill1112's Avatar
Default Re: Skip
Don't know.
Old Dec 18, 2013 | 03:29 PM
Default Re: Skip
1. A can of sea-foam in the next tank of gas.
2. new plugs
3. new plug wires
4. anybody's guess
( I didn't mention fuel pump or filter cause you say it only skips at idle ... )
Old Dec 18, 2013 | 04:04 PM
Mrmiata's Avatar
Default Re: Skip
I'd be looking for a CPS to ride shotgun with me myself.. "unless" you've replaced it recently with a Bosche brand..
Old Dec 18, 2013 | 06:35 PM
Padgett's Avatar
Default Re: Skip
Clearing when you rev sure sounds like plugs getting fouled. Can also be affected by weak spark or resistive plug wires.
If here we could put a scope on it. Any trouble codes in history ? (My Jeep tracks misfires but does not look like the CF does.)
If you have an IR gun you could check for a cool cyl when misfiring.
Old Dec 19, 2013 | 05:49 PM
Bill1112's Avatar
Default Re: Skip
Thanks Guys. I have a Bosch CPS I will install it over the weekend. I will also read the codes and see what comes up.
Thanks Again.
Old Dec 19, 2013 | 08:32 PM
Padgett's Avatar
Default Re: Skip
Just a thought that I have seen on other cars: if the CPS is giving problems wouldn't the tach be jumping around ?
Usually a jumping tach indicates a primary ignition problem but something in the secondary ignition (coils, wires, plugs) won't.
ps another thing that happens when you rev is the alternator output increases possibly enough to overcome a weak plug or coil.
Old Jan 4, 2014 | 08:07 AM
Bill1112's Avatar
Default Re: Skip
Well I seemed to have solved the problem changed the fuel filter and have not had it happen again.. maybe it will stay that way.
Thanks for everyone's help.
Bill
bby412
Apr 26, 2014 06:52 PM
crossfirees
Aug 2, 2012 07:52 PM
gryfan
South Forum
19
May 11, 2012 07:27 PM
gilbert20m
Apr 26, 2008 03:17 PM
rpr1bob
Apr 16, 2005 06:53 PM
