Clunking Noise From Parcel Shelf Area
Old Jan 30, 2014 | 01:33 AM
doctrine_chinko's Avatar
Default Clunking Noise From Parcel Shelf Area
Hi guys, gals,
I have a 04' coupe and have been loving it since the day I have had it.
I recently noticed (in the last week) a clunking noise as if something metalic is hitting something else when I drive over bumps.
I initially thought it might have something to do with the suspension, so I went to the back of the car and pushed down on the rear of the car, but couldn't hear any noise.
My friend offered to jump in the boot so that he can listen to pin-point where the sound is coming from (rear left, rear right, rear center, etc.) and he told me that it sounds like it's coming from the parcel shelf which is between the boot and the front seats.
Is it possible that something is loose inside the parcel shelf compartment? And is it something that can be fixed by myself?
Any suggestions would be greatly appreciated.
Thanks guys/gals.
George H.
South Australia
Old Jan 30, 2014 | 09:03 AM
Default Re: Clunking Noise From Parcel Shelf Area
Originally Posted by doctrine_chinko
Hi guys, gals,
Thanks guys/gals.
George H.
South Australia
Maybe it is the welding on the sway bar bracket, maybe not too visible as it is behind the wheel and attached to the trunk floor.
It has happened before, go here.
Old Jan 30, 2014 | 06:02 PM
Maybe it is the welding on the roll bar bracket, maybe not too visible as it is behind the wheel and attached to the trunk floor.
So, the link leads me to the Rear Sway Bar Bracket cracking away from the body... How would I check/confirm?
And would this mean that I can fix this issue with some welding?
Old Jan 30, 2014 | 06:25 PM
Check by looking.
The repair is basically simple but needs some thought and a doubler welded in place to share the load around.
Old Jan 30, 2014 | 06:33 PM
Check by looking.
Thank you so much for your advice!
Do I simply jack the rear end of the car up and look under the wheel arch?
Or do I a take the boot inner-lining out and look there?
Old Jan 30, 2014 | 06:38 PM
Under .........
Yeah, I said roll bar, sway bar.
Go here as well.
and here.
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
