tcu
Old Mar 9, 2014 | 01:24 PM
austinbarrylee's Avatar
Default tcu
Is TCU retune recommended for a mod SRT6 or is it a waste of money and not needed.
Old Mar 9, 2014 | 02:02 PM
Da55id's Avatar
Default Re: tcu
I got it done and am very happy with it! I got it as a bundle all at one time...tune, tcu, pulley. Shifts faster, crisper. w mode now autoshifts at redline...it gets busy at WOT SO UT's awesome not having to watch/time the tach
Old Mar 9, 2014 | 04:27 PM
32krazy!'s Avatar
Default Re: tcu
worst mod you can ever do. massive afr spikes, clutch failures and all around a bad mod. do so at your own peril you have been warned
Old Mar 9, 2014 | 04:31 PM
Default Re: tcu
thanks 32krazy. dont forget to let me know about bowling green.
Old Mar 9, 2014 | 05:56 PM
32krazy!'s Avatar
Default Re: tcu
grip and i went sat just to watch. my car is scheduled for completion by the end of the month. looking at a april 12 day at bowling green
Old Mar 9, 2014 | 06:05 PM
Default Re: tcu
ok cool. i am still waiting on mine to get finished. the 12th i know i cant make it. thunder of louisville. opening ceremony for the derby. but i can make it the next week saturday.
Old Mar 9, 2014 | 06:54 PM
32krazy!'s Avatar
Default Re: tcu
sadly thats the only test and tune for april. may has the nite runs all month
Old Mar 9, 2014 | 08:55 PM
Da55id's Avatar
Default Re: tcu
Hmm...not my experience at all. Is there something i should be looking out for symptom wise? I asked for a conservative set of tunes, and pulley is 65mm w/single CAI. Next week Wavetrac gets installed.
Old Mar 9, 2014 | 10:01 PM
S. Artee's Avatar
Default Re: tcu
Something here doesn't sound right...
Old Feb 26, 2015 | 02:38 AM
dinasrt's Avatar
Default Re: tcu
Steve, I know that you have datalogged this more than anyone probably, so I have a few questions I hope you wouldn't mind answering. Aren't afr spikes normal during the shifts? Aren't afr's a function of the ECU, not the TCU? Is it possible that the ECU would iron out the spikes a bit after a little adaptive learning? Finally; Has anyone actually popped an engine, or fried a convertor because of this TCU mod(I haven't heard anything about that here)? Sorry for all the questions, but I'm just trying to understand it all since I just plugged in my newly tuned TCU from Eurocharged today. After initial trial run(took it a bit easy), I'm loving it! I'll need to do some datalogging before bringing it to the track I guess. I'm also guessing this was only a problem when pushed near to, or at RPM limiter through the gears, yes?
Old Feb 26, 2015 | 03:25 PM
Guran's Avatar
Default Re: tcu
For me it's perfect. Streetracing. I have rebuild my gearbox
with other discs and more discs. Now it can handle over 1500 nm.
And the TCU have no limit at all. No restriktions at all. Full load.
Its like a car with manual transmission and you dont use the clutch.
A little tricky to run normally, but i can live with that.
rfourt
Aug 12, 2020 07:27 PM
amx1397
Jan 24, 2016 02:12 PM
rfourt
Sep 25, 2015 01:38 PM
RacerXofFL
Sep 15, 2015 05:00 PM
MAXIMUM
Aug 4, 2015 11:04 PM
