Horsepower
Old Mar 11, 2014 | 01:51 AM
pburchette's Avatar
Default Horsepower
What can I do to bring more horsepower to my coupe?
Old Mar 11, 2014 | 03:36 AM
TomSRT's Avatar
Default Re: Horsepower
Buy an SRT6 j/k
Search for more hp, lots to read, but most common are cai, pulley & tune
Good luck
Old Mar 11, 2014 | 07:20 AM
PNA's Avatar
PNA
The Eurocharge Tune is about 300 dollars when on special. Best bang for the buck. 24hp
Lots of other things to do including what TomSRT noted. The Needswings CAI (single or double), etc. It gets into more money though, but I'd say for about 1200 you can do most all of the mods and I believe end up somewhere in the 260ish HP range if done properly.
I'm happy with my tune.
Old Mar 11, 2014 | 10:39 AM
I will endorsewhat PNA said 100%.
Three elements wil get you more power;
1) get more and cooler air to theengine
2) get less restriction in the exhaustto get that additional air volume thru the engin
3) Get a performance tune.
In addition, you can change out the injectors to get more fuel to the engine. And you can get a larger throttle body.
A dyno tune will take that 260 HP higher. Arguably into the 275 range or more.
One "performance" mod is a Sprint Booster" There are several available from members here. It doesn't add HP but does improve accelerationby modifying the throttle signal from thepedal tothe Engine control system.
At no cost to you, is a throttle reset. Do a search here for the proceedure.
Some put stickers on their cars assuming it improves performance. Don't laugh, there are stickers that actually help. One says Eurocharged and the other says Needswings.
Old Mar 11, 2014 | 10:48 AM
Then add the adjustable camber to the rear of your car, get the rear end realigned a bit, come to the dragon and learn to drive like Franc and no one will keep up with you.
HICKORY? What state is that in?
Old Mar 11, 2014 | 11:17 AM
Wake up Mark : North Carolina ( never did figure out why they have tar on their heels, bet the wife gets PO'd every time they walk into the house )
Old Mar 11, 2014 | 12:01 PM
Read this thread for actual dyno figures on NA and SRT's.
Add what is considered to be the approximate percentage losses due to drive train losses and you should see what the approximate gross hp is at the crank..
What is a typical loss ? Lets say 20%. So if we had a car putting out 200 hp on the dyno we would be seeing 80% of the gross power. (200 ÷ 80) x 100 = 250 hp.
Old Mar 11, 2014 | 12:07 PM
That is what I thought, he's a bit farther from the Dragon, but given the roads, he could be there faster than I can.
So, why are you not on the attendance list for April 3, pcurchette?
https://www.crossfireforum.org/forum...il-2014-a.html
Old Mar 11, 2014 | 01:21 PM
05roadsterguy's Avatar
Because he has never made it past the welcome forum? He might have no idea that the dragon even exists.
Old Mar 11, 2014 | 02:07 PM
pburchette's Avatar
Default
Nope. I had no idea. Haha. Where's it located?
Old Mar 11, 2014 | 02:16 PM
S. Artee's Avatar
Default
Not sure if that was tongue-in-cheek, but 20% is high for parasitic loss.
These cars should be closer to 15-18%.
Old Mar 11, 2014 | 02:42 PM
I was going to use 15% as that is a much quoted figure, but I upped it to be very generous and try to approach the 260 to 300 hp quoted often by members here.
Otherwise we would have got (200 ÷ 85) x 100 = 235.3 hp at the crank which would have been very disappointing to some.
This figure is not even close to those numbers.
If you thought you had 290 at the crank then the hp on the dyno would be 232 to 246.5 hp. Not close again to the stated dyno numbers.
Old Mar 11, 2014 | 03:02 PM
6 years ago and since, we have had members complaining at the 30% parasitic loss shown via the baseline dyno reads.
I was 143 hp at the wheel with engine specs at a supposed 215 HP at the crank.
Keep in mind the dynos are possibly different and give different reads depending on ambient conditions.
To see actual gains one must attempt consistant conditions and testing calibrations. The percentage of gain measured at the wheel. And that value can be interpreted mathematicaly from the crank but not measured precisely.
Old Mar 11, 2014 | 05:04 PM
S. Artee's Avatar
I had a similar issue with my baseline, 280-ish. Even with the fuses pulled, the car still let off at around 5200rpm... After much head scratching, we discovered it was the speed governor that was stopping us.
Spoke with EC about this and they said when establishing baseline on the xf/slk/etc they make a 3rd gear run versus 4th as the numbers are nearly identical.
Fwiw, of course...
Old Mar 11, 2014 | 06:15 PM
143 hp at the wheels has to be wrong, Valk got 170 hp without a tune.
Old Mar 11, 2014 | 06:21 PM
sk8erjosh09's Avatar
I've seen the 170whp number thrown around a lot. Like stated earlier though, every dyno is different, calibrated differently therefore reading differently. I've seen dyno sheets for E55's ranging from 360whp to 440whp. That's a pretty huge difference and almost everytime they all run around 12 flat in the quarter lol.
Old Mar 11, 2014 | 08:02 PM
Dave, as I explained different dyno.
I don't believe I passed much more than 170 ATW on the first tune up.
Dave, I can only relay the numbers I was given. I cannot change them just to please you.
Old Mar 11, 2014 | 08:41 PM
Fwiw, of course...
I believe I might have been their first manual tranny. They spent a lot of time trying to figure out how to dyno my car for the same reason. Not sure what gear, and what fuses they pulled, to get 'er done. But all future dyno' runs, they had it nailed.
Old Mar 11, 2014 | 08:51 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Many do change the numbers just to please themselves.
Old Mar 11, 2014 | 10:24 PM
Bigkid's Avatar
Changing the numbers any other way can become expensive.
