Radio powers on but no sound?
Old Apr 12, 2014 | 07:56 PM
cuziamninja's Avatar
Default Radio powers on but no sound?
I just installed a Sony aftermarket radio into my Crossfire Coupe, Ive got the correct harness and connected all the wires to the correct color. The harness had a leftover wire for the Remote out, which I assume turns on the cars built in sub, however I didn't find an extra wire coming from the crossfire that would power that! Any ideas where this would be? Or any other explanation why no sound comes out, not even static?
Old Apr 12, 2014 | 09:16 PM
Mrmiata's Avatar
Default Re: Radio powers on but no sound?
Pin out schematic that shows the amp turn on in the harness.audio pinout.jpg
Position A5 on the back of your old stereo.. just match your new lead to the adapter position when plugged in.
Old Apr 12, 2014 | 11:57 PM
Adrian_X's Avatar
Yup when I put in my new Kenwood BT955 unit in the car I had to manually put the new pin from the harness to match slot a5. Worked like a charm.
Old Apr 21, 2014 | 02:47 PM
Still can't get the harness to work!
I got this harness from Best Buy:
Metra Speaker Connector for Select Volkswagen Vehicles VW-9000 - Best Buy
I tried wiring it exactly color to color, and no sound. I then tried switching the red and yellow wires, still no sound. Lastly I tried connecting the remote out wire to the blue/grey wire that was plugged into the A5 slow on the plug coming from the car. Still nothing. What am I doing wrong?
Old Apr 22, 2014 | 10:52 PM
Do I have the wrong harness? I still can't get sound. Should I be using this one?
Metra 70-1786 Receiver Wire Harness For select 1994-08 Chrysler, Land Rover, Mercedes, and Saab vehicles at Crutchfield.com
Old Apr 23, 2014 | 12:02 AM
Adrian_X's Avatar
If I'm not mistaken, the 70 1786 is the harness I used too in the end btw.
Old Apr 23, 2014 | 12:09 AM
Mrmiata's Avatar
Hmm.. dead outputs on the RCA? I bought a stereo "new" off ebay before that the internal amp was doa..
Yeah, thats what I'm looking at.
But what do you do with the RCA cables?
Old Apr 23, 2014 | 12:22 AM
Mrmiata's Avatar
Problem solved! You do have those plugged in to head unit right? If not or no rca outs.. you need to connect them or get the other harness that wires to speaker leads..
Old Apr 23, 2014 | 12:27 AM
Originally Posted by Mrmiata
Problem solved! You do have those plugged in to head unit right? If not or no rca outs.. you need to connect them or get the other harness that wires to speaker leads.. With that adapter.. you have to add them to the oem speaker harness wires..
I'm a bit confused what you are saying. I don't have the harness with the RCA wires, I just have the basic Metra harness with the colored wires. You are saying I need to get the new harness and connect the RCA wires to the head unit?
Old Apr 23, 2014 | 12:28 AM
Adrian_X's Avatar
Scratch that, my memory was funky on that one. I used the speaker wire connections not the RCA inputs when I wired everything up. I forgot what model of the harness was exactly though. Ugh
Old Apr 23, 2014 | 06:54 AM
Mrmiata's Avatar
The link from crutchfield.. they only have the rca connection and that's where I was misled . Back to bench test the stereo. Yellow to red - red to yellow hook up speaker leads - insert amp turn on lead. It really is this simple so I'm wondering about HU. No blown fuses right?
Old Apr 23, 2014 | 12:05 PM
Default
I have red and yellows switched, and the rest of the colors coordinating with the matching color. I'm not sure which wire to plug the amp turn on wire into! Coming from the harness that plugs into my Sony radio, the wire says remote out, and is blue/white. I've tried plugging it into the blue wire on the wires coming out of the car. I've even tried the blue/pinkish wire. None of them work!
Old Apr 24, 2014 | 06:42 PM
This is what the back of my radio looks like. Does that mean I should get the harness with the RCAs?
Old Apr 24, 2014 | 07:03 PM
Mrmiata's Avatar
Not necessarily .. it makes it an "option" but not if your output is less than 4 volts on them. Have you bothered to "bench test" that as I suggested? As I said, I have purchased a new one with a dead internal amp before.
Old Apr 24, 2014 | 07:04 PM
What do you mean, bench test?
Old Apr 24, 2014 | 07:14 PM
Mrmiata's Avatar
set it on a bench.. hook up a power source and spare speaker to make sure the stereo is working.. antenna helps to. I had actually tore the dash out of the Miata..wired in the stereo and "nothing". That's when I did as described above and had no doubts I got a bum stereo. Went to wally world and bought one then made arrangements with the ebay seller to return the other one.
smokey847
Nov 12, 2015 11:54 PM
LE Cross
Sep 14, 2015 01:20 PM
BEATv1
Sep 10, 2015 12:58 PM
rdougc
Sep 5, 2015 10:30 PM
pioneer4x4
Jul 27, 2015 02:04 PM
