Euro charge problems
Old May 21, 2014 | 09:29 PM
Blackout317's Avatar
Default Euro charge problems
hey guys
So a little over 6 months ago i got the eurocharge tune for the crossfire and ran it on a old laptop that i had laying around the shop. Since then the laptop has gone to crap. i have a new laptop with windows 8.1 but cant seem to get the program to run. I have contacted eurocharge but have come up empty. I have tried there suggestion with disabling the firewall but no luck. sorry if this is the wrong section for this i couldnt think of anywhere to post it.
Thanks in advance
Tanner
Old May 21, 2014 | 10:08 PM
crookedview's Avatar
Default Re: Euro charge problems
Do you get any kind of error message? If so, can you post a screenshot?
Old May 21, 2014 | 10:10 PM
Default
No error all I get it the pop up to run as admin then the blue circle to show its loading then nothing.
Old May 22, 2014 | 04:43 AM
Selbyl's Avatar
You need to run the application in a compatibility mode. Right click the icon, then properties and then the options should be there and select Windows 7.
Old May 22, 2014 | 10:55 AM
Default
tried windows compatible mode for windows 7 and vista with still the same no run results
Old May 22, 2014 | 11:05 AM
xme's Avatar
xme
Try right clicking on it and running as administrator too... I've yet to see anything that runs on windows 7 that won't run on windows 8...
edit - you also may try disabling real-time protection in your antivirus (or in windows defender, depending on which you're using) *but make sure you re-enable it after testing or when you are finished*
Old May 22, 2014 | 12:51 PM
Buck Spunni's Avatar
It's been a while but I seem to remember using my wife's Windows 7 laptop in XP compatibility mode.
Old May 22, 2014 | 06:19 PM
Hey guys
Thanks for all replays so far. i have tired disabling the firewall, my anti virus (windows defender is off) running as admin and running in compatibility mode. Still no luck the same things are still happing just the loading circle and then nothing.
crossfireusa
Oct 28, 2015 12:03 AM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
81's
Sep 13, 2015 04:34 PM
rdougc
Sep 5, 2015 10:30 PM
