completed front mount twin turbos on a N/A :)
Old Jun 8, 2014 | 10:51 AM
Speedy4x4's Avatar
Default completed front mount twin turbos on a N/A :)
Just found this on ebay, a 2004 XFire custom wide body show car, best part FRONT MOUNTED TWIN TURBO FROM A N/A.
i am going to be emailing him many questions and try and get more pics/
http://www.ebay.com/itm/Chrysler-Crossfire-Base-Coupe-2-Door-2004-CHRYSLER-CROSSFIRE-CUSTOM-SHOW-CAR-ROAD-CAR-/191203860795?forcerrptr=true&hash=item2c84a3613b&item=191203860795&pt=US_Cars_Trucks
Old Jun 8, 2014 | 10:55 AM
Speedy4x4's Avatar
Default Re: completed front mount twin turbos on a N/A :)
forgot to post this pic
Old Jun 8, 2014 | 11:01 AM
robby363's Avatar
All show and no go. It was up for auction on ebay about 2 weeks ago and the highest bid was $17,000.
Old Jun 8, 2014 | 11:07 AM
Speedy4x4's Avatar
Originally Posted by robby363
All show and no go.
just some pics showing that twin turbos do fit on front and how he ran piping, for all those that said it can't be done.
Of course i sure boost is "very" minimal since it is a original N/A car.
AT LEAST HE DID IT
Old Jun 8, 2014 | 11:14 AM
robby363's Avatar
AT LEAST HE DID IT
It's all show, this car has been up for sale 4 or 5 times over the years. If the Crossfire could have been turbo charged it wouldn't still be trying to be done 10 years later with no luck.
Old Jun 8, 2014 | 01:02 PM
Old Jun 8, 2014 | 01:24 PM
Showed up here in 2013
Showed up in 2012.
Same car 2007
Same car 2006
You get the idea.
Old Jun 8, 2014 | 01:53 PM
Mrmiata's Avatar
Bjames - Turbo with 4 psi and working. Josh may have found the answer for more boost. It's just around the corner at this point.
Old Jun 8, 2014 | 02:57 PM
Just don't say 'in two weeks', those words are the kiss of death.
Old Jun 9, 2014 | 04:25 AM
bullpup's Avatar
It's a well done car, the body is all metal fabrication. probably the bumpers etc are glass and bondo. but thats normal
You would be able to retrofit some original headlights in the front quite easily. get a mod plate and your done.
I wouldn't expect hi-boost running on a stock motor. would need a full rebuilt to cope with the boost.
its pretty good value. i don't see what the probably is with people, i would buy it
Old Jun 9, 2014 | 06:02 AM
ImportLabSRT's Avatar
That car was never driveable over idle. The shop that built never figured out a solution for tuning.
Old Jun 9, 2014 | 07:18 AM
bullpup's Avatar
you seen the eurocharged one, its only got 1 turbo though
Old Jun 9, 2014 | 07:24 AM
Mrmiata's Avatar
Looks a whole lot like an SRT6 .. which already knows what to do with boost.
Old Jun 9, 2014 | 07:28 AM
bullpup's Avatar
how much boost does the srt-6 run, 18ibs or something?
Old Jun 9, 2014 | 08:15 AM
That setup does not exist anymore. Currently that car runs a PTE-5857 at 14psi on low boost and 24psi on medium boost. Self tuned by the owner using the factory computer and a 3.5bar MAP... oh and is converted to E85 with a whole bunch more.
Old Jun 9, 2014 | 09:40 AM
sk8erjosh09's Avatar
Ask this guy how he knows
Old Jun 9, 2014 | 08:04 PM
LMAO.....some are slow to understand......but, he will get there....
Old Jun 9, 2014 | 08:06 PM
I know nothing
Old Jun 9, 2014 | 08:48 PM
Speedy4x4's Avatar
Default
So with being a stock N/A 11:1 with turbos added. The calculated compression at 24 psi would be 28.959:1. Even running 85% alcohol how is it able to run and drive????
Old Jun 9, 2014 | 09:00 PM
Mrmiata's Avatar
Did you miss the "looks like an SRT6" comment? An N/A in theory is safe up to 6 psi. At least that's what I've gathered over the last couple of years..
