O2 Sensors
Old Jul 16, 2015 | 08:22 PM
Mark McKay's Avatar
Default O2 Sensors
I have a 2006 roadster. Engine light came on and I had the dealer diagnose the problem. Codes read bank 2 sensor 1 slow to read and bank 1 sensor two slow to read. For what they wanted to replace I left and ordered all four new Bosch sensors and replaced them. I hadn't driven 30 miles and the check engine light came back on. Sure enough, the same messages came up when I had someone else hook up their ODBC. I'm at a loss as I can't believe all the new sensors were bad. Has anyone had this happen or have any suggestions? Thanks in advance for any help.
Old Jul 16, 2015 | 09:08 PM
blackpepper's Avatar
Default Re: O2 Sensors
Check your connectors
Old Jul 16, 2015 | 09:25 PM
Mark McKay's Avatar
[QUOTE=blackpepper;842356]Check your connectors[/QUOTE Thanks will do that.
Old Jul 16, 2015 | 09:40 PM
bspence's Avatar
Use of silicon sealant on the engine that is not "safe for oxygen sensors" will cause sensor failure shortly after it's applied.
Old Jul 16, 2015 | 11:54 PM
JEFASOLD's Avatar
Get your own OBDII reader. then reset the codes, you may need to do this two or more times until the computer learns that they have been changed and makes adjustments. Checking connections won't hurt either. Did you do anywork on or around the exhaust, bits of carbon etc. can be knocked loose and clog the sensors, a little cleaning may renew their efficiency.
Old Jul 17, 2015 | 06:50 AM
Mark McKay's Avatar
Thanks Jim. I didn't do anything but change sensors. Guess I'm going to have to buy my own reader.
Old Jul 17, 2015 | 12:39 PM
Classic example of the limitations of OBDII code readers. They tell you what code it is but they cannot tell you what parts need to be replaced, only suggestions. There are too many variables (ie loose ground, loose wires, intermittent, bad gas, bad sensor). Valuable tools needed are a good VOM, a quality multimode OBDII reader, and the service manual (for circuit testing), or just throw parts at it until its fixed.
Old Jul 17, 2015 | 01:18 PM
I was getting O2 codes, can't remember just what they were - changed all plugs and plug wires and the problem went away. (I knew the plugs and wires were bad, the car had 101,000 on it.)
SOMETIMES the code does not mean a bad sensor but that the sensor's data is out of bounds. Question is, is it out of bounds due to a bad sensor, or is the sensor telling the truth and something ELSE is causing the out of bound condition? In my case, the O2 level was showing too high because it WAS too high, the engine was missing and therefore passing unburnt O2 thru.....
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
