window switches
Re: window switches
Check out:
https://www.crossfireforum.org/forum...=window+switch
You have to remove that center surround first. You just have to use a bit of bruit force, it will click then removing, don't worry you are not breaking anything, it has some grooves on the fittings to hold it in place so just pull to work them loose. Be carefull not to scratch anything though, put a cloth down etc..
o55ie18
10-05-2015 05:50 PM
