Windshield washer nozzel
Old Jan 27, 2016 | 10:23 PM
Barto's Avatar
Default Windshield washer nozzel
Hello all,
My drivers side Windshield washer nozzel seems clogged. The left portion splits the spray some going over the roof some spraying downward totally missing the windshield. The right side of the drivers side nozzel doesn't work at all. Any thoughts?
Thanks,
Bart
Old Jan 27, 2016 | 10:27 PM
Default Re: Windshield washer nozzel
Originally Posted by Barto
Hello all,
Thanks,
Bart
The nozzle can be snapped open and the nozzle cleaned, it can then be closed and the nozzles adjusted with a pin in the hole.
Old Jan 28, 2016 | 07:51 AM
Barto's Avatar
Thanks onehundred80, sounds easy enough....I'll check it out this weekend
Old Jan 28, 2016 | 09:04 AM
If you can, pull off the hoses going to each nozzle and get the fluid pumping through the lines. If someone has filled the tank with water alien life forms in the tank and the slime can fill the lines. If it repeats you will have to remove the tank and clean it out, the slime jammed the level sensor on mine and it said empty when it was full.
The nozzles snap open using the tab at the front, easy peesy. Taking out the tank, if required, would allow you to clean out that area, mine had small leaves and gunk that had come down the cowel drain hose. I cleaned and sprayed the area with a rust proofing, there was no rust but ......
If I opened that area again I would extend the drain hose to the outside more.
You can see the Crossfire Service manuals on this forum, they explain a lot.
Old Jan 28, 2016 | 06:57 PM
Steve Jr's Avatar
I've never seen one adjust like that! 180's right, stick a pin in it. WoW
Old Jan 29, 2016 | 11:52 AM
PNA's Avatar
PNA
If a pin doesn't work, which my bet is it won't, you'll need to remover the cowel, remove the nozzle and drill out the inlet from the jet tube connection area. The nozzles are heated and the plastic in the base of the nozzle melts. Once this happens, it won't allow water to flow through the jets. A small drill bit inserted and drilled through the connector will open up the plastic again and allow the fluid to flow through the jets. It's the only way to get them to work again, aside from buying new nozzles (which isn't necessary).
Old Jan 29, 2016 | 12:07 PM
The pin is only to adjust the nozzles and not to clean them. Slime had built up in my lines, almost blocking them completely.
The heaters have been known to melt the plastic as you know.
Mocephus
Dec 11, 2019 10:36 AM
HOT FIYA
15
Feb 10, 2016 06:14 PM
jmartinpadilla
Jan 8, 2016 06:30 PM
jmartinpadilla
Jan 6, 2016 07:22 PM
BisB
Dec 31, 2015 10:41 AM
