2006 infinity Radio Amp
Old Mar 27, 2016 | 06:21 PM
Dcwhite67's Avatar
Default 2006 infinity Radio Amp
Does anyone know the correct part # for a 2006 infinity radio amp?
I am over a 100 miles from the car. I don't know if it is a loose connection or a bad amp. I may be need to replace the unit. I will be able to look at the car next weekend.
I know it is not my radio or speaker " for sure "
Radio plays sometimes but most of the time does not play.
Thanks
Old Mar 28, 2016 | 09:10 AM
zip439's Avatar
Default Re: 2006 infinity Radio Amp
Don't buy anything until you have determined your problem. The amp Chrysler #5189332AA new cost $422. You can find a good used one on this web site in the "Market Place" section for less.
P.S. It is best if you reply in your original thread. Keeping everything in one thread helps us help you as all the info is much easier to follow.
Old Mar 28, 2016 | 09:18 AM
Also, the Infinity amp is not mandatory.
With a bit of creative wiring, any good aftermarket amp will work.
Old Mar 28, 2016 | 10:04 AM
Dcwhite67's Avatar
O K, I will do that in the future. Thanks for your help.
Old Mar 28, 2016 | 10:06 AM
Dcwhite67's Avatar
Thanks for that info. I am going to have it checked out this weekend.
Old Mar 28, 2016 | 10:25 AM
Take this with you when you have it checked out :
Old Mar 28, 2016 | 11:29 AM
Dcwhite67's Avatar
Thank You so much for this information.
Old Mar 28, 2016 | 11:58 AM
Dcwhite67's Avatar
I made a copy and sure will take it with. me.
Thanks again.
Old Mar 29, 2016 | 09:13 AM
zip439's Avatar
BEFORE YOU take your car any where check the fuses # 8 for the radio, and #23 for the amp in the fuse box under the hood on the drivers side. Also check with a code reader if you have any DTC Diagnostic Trouble Codes. Many items use the same grounds as the radio and amp it may help identify where your problem is if there are related DTC.
Old Mar 29, 2016 | 11:12 AM
Dcwhite67's Avatar
I sure appreciate your help. I will check the fuses and see if a friend has a DTC tool.
Thanks again
Old Apr 11, 2016 | 11:53 AM
Dcwhite67's Avatar
Thanks again
I did check the fuse all good. Then bought a like new factory radio from a forum member, it works great. Then I found on ebay the same Amplifier that was in my Crossfire and installed it over the weekend. Now, radio and CD player work fine. Yea!!!
Again , I want to Thank You all you guys for the info and help on the forum.
Old Apr 11, 2016 | 01:42 PM
Thanks for reporting back !!!!!
I try to help, and zip439 is a fart smucker also.
Dcwhite67
Nov 14, 2023 10:57 PM
cuziamninja
Apr 19, 2016 05:28 PM
boostmonkey
Racing
Mar 23, 2016 10:28 PM
Inflixo
Mar 23, 2016 01:48 AM
cuziamninja
Mar 16, 2016 10:39 PM
