2004 crossfire ticking noise
Old May 3, 2016 | 08:31 PM
pcarsdoc1's Avatar
Default 2004 crossfire ticking noise
Hello I just bought my 2004 crossfire last week and now its making a engine ticking noise when its ideling I don't believe it makes the ticking noise when u rev it up just when u idel any help on this would be great . and i was wandering y my oil light is on its got the right amount of oil in it and there's a sticker on the window that said the oil just been changed so maybe they didn't reset the light or maybe a sensor not sure help on this would also be great
Old May 9, 2016 | 10:50 AM
liljay's Avatar
Default Re: 2004 crossfire ticking noise
Automatic or manual. If it's manual, check the belt tensioner Damper. It could be the bushing on the damper are worn off and the damper is rattling. You should not have an oil light on unless you do not have the proper amount of oil. Maybe a sensor or over filled. To much is just like not enough.
Old May 9, 2016 | 06:07 PM
Bill F's Avatar
Or it might be the fuel injectors.
Old May 11, 2016 | 02:20 AM
MB04XFIRE's Avatar
My car too was ticking when idling.. Apparently it's a common thing with these engines.. Specially when the engine is cold.
I read a post on here as to how to fix this problem. I got a can of seafoam, put half in the gas tank and the other half in the oil. Drove for a hundred miles or so and then changed the oil.. This stuff will clean your injectors and clean your engine right out... Ticking is now gone... The ticking actually went away after 15 minutes of idling after putting the safoam in the engine... And it hasn't come back since.. Go to the search and enter seafoam.. You will find the posts that give a step by step as to what to do and how much to put.. Good luck
eikon
Jul 26, 2017 03:25 PM
Da55id
Apr 19, 2016 03:48 PM
theglot
Apr 16, 2016 10:30 AM
patten316
Apr 6, 2016 12:44 PM
wayne26
Apr 4, 2016 11:05 AM
