Air Con Growling
Old Jun 11, 2016 | 02:55 PM
Reevz1977's Avatar
Default Air Con Growling
Hi Folks,
My air con, though working just fine, is making a growling noise that gets worse the higher the setting. It had a new air con motor 12 months ago. Any ideas or advice on where to start looking?
Old Jun 11, 2016 | 03:35 PM
Default Re: Air Con Growling
Maybe leaf debris got in ?
Old Jun 11, 2016 | 03:41 PM
Reevz1977's Avatar
Many thanks for the prompt answer!!
I did wonder if that was the case - without sounding like a complete idiot, where would I look?
Old Jun 11, 2016 | 04:31 PM
Raise the hood.
Remove the caps at the bottom of the wipers (that hide the nut that holds them on, if they have not fallen off like all the rest).
Take the nuts off each wiper.
Grab each wiper and pull/twist/work them off their spindles.
Remove all the torx screws in the plastic cover under the wipers, and lift the cover off.
All the way on the passenger end, you will see the squirrel cage blower, it will be full of leaves/pine needles/etc.
Vacum out the blower cage and all the vents - vacum out the ENTIRE area under the cover.
Put things back together. You are done.
(This will also keep the drains from clogging and backing up, allowing water to fill the area and overflow into the squirrel cage area and flowing down under the carpet on the passenger side - which leads to water in your sound system amplifier, as well as other items.
Old Jun 11, 2016 | 04:36 PM
Reevz1977's Avatar
Raise the hood.
Thank you so much!!! That's really appreciated!!
As always, this forum NEVER disappoints!!
Old Jun 11, 2016 | 06:13 PM
BTW, those wiper nuts are 15mm ....
Thanks pizzaguy, I was just too lazy to type all that.
Old Jun 11, 2016 | 06:18 PM
Or if you wanted less work you could remove the cabin air filter under the dash and vacuum out that area. You can see the fan blades there. Usually it gets leaves and twigs in there, even if it does not solve the growl the area will have been cleaned.
Old Jun 11, 2016 | 06:31 PM
Reevz1977's Avatar
Where would that be located?
Many thanks
Old Jun 11, 2016 | 06:42 PM
Many thanks
There are 2 phillips screws under the glove box holding the black plastic cover in place,
remove them and the cover.
You will then see a plastic slidey thing that will let you remove the fan cover, and another one that allows you to change the filter.
Old Jun 12, 2016 | 09:07 AM
Raise the hood.
Doing both the inside and outside (sans a bad blower motor) insures all the debris that could be causing this, is removed and no longer an issue. If there is a large amount of debris on the outside section, be sure to continue and inspect (pizzaguys suggested for water leaking into amp area and wiring throughout) for any past water intrusion. If present and not address it could play all sorts of heck with whatever was wetted. Afterwards, gently spin the cagefan feeling/hearing if anything is rubbing/hitting the cage (before closing it all back up). If you feel/hear nothing, operate it with just the ignition in the on position (not started/running) so see if any noise is still there. Good luck!
debradegiovanni
Jul 12, 2016 08:13 PM
Rcking323
Jun 12, 2016 09:16 AM
BibaResto
Jun 9, 2016 08:40 PM
pjs626
Jun 7, 2016 12:27 PM
bucketlisted
May 15, 2016 12:49 PM
