propshaft bush
Old Jun 18, 2016 | 04:35 PM
reggell1's Avatar
Default propshaft bush
hi guys,
knocking noise coming from rear end when accelerating fast from standing still, my mechanic told me it is rear centre prop shaft bush, but Chrysler wont sell me bush, they want to sell me complete prop shaft at over a grand. anyone any ideas out there. ta much.
clive, 07 9797 36 131.
Old Jun 18, 2016 | 04:44 PM
kingdavid54's Avatar
Default Re: propshaft bush
Originally Posted by reggell1
hi guys,
Yea😃 needswings.com has what you need. Happy motoring!
Old Jun 18, 2016 | 04:46 PM
reggell1's Avatar
ta, will have a look
Old Jun 18, 2016 | 05:20 PM
hi guys,
All bearings have a number on them put there by the manufacturer. If you can see the number just order it from a bearing outlet.
Most bearings are a standard size to keep the costs down, I expect that this is no exception. Bearings of this size are no more than $30 each maybe <$20 each, depending on the usage in general.
Old Jun 18, 2016 | 06:27 PM
zip439's Avatar
As you know our Xfires are built on the Mercedes 320 platform. Your part is here:
03 2003 Mercedes SLK320 Drive Shaft Center Support Bearing - Driveshaft & Axle - ***, Febi, National - PartsGeek
three choices $10 to $23 US dollars.
Old Jun 18, 2016 | 07:49 PM
There you go, no need to get shafted on these parts. You have to keep your bearings when buying spares.
Old Jun 18, 2016 | 09:54 PM
don't listen to that BS get the bearing KIT from needswings,, the Bearing is probably not bad, but the rubber housing around it is bad replace the whole thing.
NeedsWings Performance Products. Driveshaft Support and Bearing this is same p/n for both srt and limited.
if you need the flex coupling, which i don't think u do the srt 6 and the limited take a different p/n jim
Old Jun 18, 2016 | 11:18 PM
Not everyone has unlimited funds to keep their car on the road, to that end they would rather spend $20 rather than $100 if that is reasonably possible.
Pushing for a sale from NeedsWings is not to be recommended for the OP as he lives in Scotland, shipping there would be prohibitive, I have priced things from NeedsWings and the shipping is too much to Canada, even with a price reduced from what the auto calculator says. Shipping is often a deal breaker, best to pick it up and bring it over as I have done before.
Old Jun 18, 2016 | 11:38 PM
what unlimited funds, ??? I am like a lot of other people am ON FIXED INCOME; AND IT ISN'T MUCH.
I understand that,,, now for the rest of the story.,,
i bought a bearing I think it was around $25.00 ,,installed it and two days later (I am harder on my car than all or you) the same noise,, the bearing housing failed,, same banging noise as before, I didn't think is was the same problem,, so i replaced the flex joints at the tranny and the rear end,,, still had the same noise,, had three mechanics check the car ,,no one could find the problem,,, so I put on my drag radials and said if i have to brake it to find it i will,, after about 4 hard take offs, it showed up as the bearing housing,, also screwed up the new bearing,, and the universal joint , so now I had replaced both flex joints, Which were good, $230 + bearing #25 + bearing kit from rob, ,, = $355.00 + labor for what could have cost 100. oh and 40 for the universal joint $45
that is why I am saying do it right the first time. jim
Old Jun 19, 2016 | 10:20 AM
I have to agree, based on experience on my end as well, replace the carrier bearing as a unit it's the proper way, the rubber housing overtime deteriorates.
Old Jun 19, 2016 | 10:36 AM
I have been on this forum for ten years and watched even longer and I can say that this carrier had not been a big problem, in fact hardly any problem at all. I personally would consider replacing it when replacing the flex joints when and if required, I have seen the flex joints cause problems many times.
Old Jun 19, 2016 | 03:17 PM
u R 100% right if U R replacing under 10 to 15 year maintenance.. but when U here the knocking and not sure if it is an axle or drive shaft ???, I have been with JS Benz for 3 years now and have seen about 20 carrier bearings go bad, 4 is Crossfires, the flex joint none, but we have replaced them because of cracks (weather and or stress cracks) I have replaced my carrier bearing twice and my flex joints once. my car has less than 60,000 miles and 7 years with the V8. jim
Old Jun 21, 2016 | 09:21 AM
zip439's Avatar
I figured most anyone might be able to figure out it is just as easy to replace the rubber bushing as well as the bearing itself as self explanatory. Certainly the OPS mechanic knows this. The point of my post was to give him an option vice going to Chrysler. Just for the record here is the bushing support for the bearing:
03 2003 Mercedes SLK320 Driveshaft Support - Driveshaft & Axle - Genuine, Rein - PartsGeek
Old Jun 21, 2016 | 10:21 AM
NeedsWings's Avatar
yes we can send you the entire assembly, I assume you have bent the bracket that encases the bearing and that is your thumping issue as it has happened to our srt6 as well as many other crossfire owners.
Old Jun 23, 2016 | 11:25 AM
reggell1's Avatar
thanks, clivemarks2000@yahoo.co.uk g81 6lw how much guys?
Old Nov 2, 2018 | 07:54 AM
DaveXFIRE's Avatar
Mercedes Part Numbers for NON SRT
Propshaft Centre Bearing - A008 981 4325
Propshaft Centre Bearing Mount/Support - A170 410 0081
Propshaft Donut/Coupling - A000 411 0000 (front and rear are the same part)
Febi Bilstein versions are readily available in UK at places like onlinecarparts.co.uk and relatively inexpensive.
Chrysler will want you to but a whole propshaft for almost £1,500
