no start
Old Jun 28, 2016 | 02:00 AM
ecenterprise's Avatar
Default no start
Put new module on my 04 started good for 2 weeks and now it turn over but will not run... plz help!!!
Old Jun 28, 2016 | 05:37 AM
Steve Jr's Avatar
Default Re: no start
What module did you replace? What was it doing, to have you work on it?
Old Jun 28, 2016 | 07:14 AM
Kingdav1954's Avatar
More information is needed like SRT or na? Automatic or straight drive? And we have to assume it's a coupe. Which module did you change? What other components have you changed on the car? When it turns over does it even attempt to start or does it just turn over ?
Old Jul 16, 2016 | 06:47 PM
I have an automatic. not sure what module was replace. It just turn over. The car is in the shop now for 2 weeks and nothing yet. they want to put a PCM in.. Need help plz
Old Jul 16, 2016 | 07:21 PM
#1 - does it have spark ? ( remove one wire from a coil pack and hold it real close to the socket and see if it sparks while trying to start )
#2 - does it have fuel ? ( check for pressure at the test port front passenger side of the engine, kinda like a big tire valve, push the schrader valve with something, don't have your eyes near )
If both 1 & 2, then just maybe a PTCM, but they very seldom ever fail.
O, and make sure you don't have any blown fuses anywhere.
Old Jul 17, 2016 | 09:56 AM
Here is some help for you - get the car out of there.
While PTCMs can fail, in 6 years and 80,000 miles of owning three Crossfires, and spending all this time on this forum, I think I can remember ONE PTCM that failed.
If the car spins over with the starter, we must determine if we have spark and at least 50 pounds of fuel pressure BEFORE we go anywhere else. Common "it turns over but won't start" causes:
1) Bad Crank sensor
2) Bad Cam sensor (kinda rare but it does fail)
3) Bad battery - (yes, it may spin the engine but not start the engine, odd I know, but I've seen it several times)
4) No fuel pressure (bad fuel pump relay, fractured solder on the Relay control module - both can be fixed with a new RCM for about $129)
5) Low fuel pressure (due to screwed up fuel pump or fuel filter/regulator)
Notice that ANY of these can fail and only 1) or 2) will throw a code and light the Check Engine light - and often, they fail and even THEY don't light the light - this, I think, leads many desparate techs to toss expensive modules at the problem. THey've already tossed one module at it and that didn't work, did it?
Old Jul 17, 2016 | 12:50 PM
lovecross's Avatar
1) Bad Crank sensor
Ditto! Well said! I replaced RCM due to stalling, (needed fixing asap). Then the crank sensor (Bosch) due to cranking & no start. (Rock Auto & Amazon; minimal parts cost & my free labor) All is well!
The check engine light only came on after my repairs and then cleared itself when driven.
LORD have mercy if your car is in a Chrysler shop (at least 99% of them). "Search" will reveal hours & hours of input*
Old Jul 18, 2016 | 12:43 AM
Going to the shop in the morning to see what going on with the car... Need help plz
Old Jul 18, 2016 | 08:58 AM
It is hard to help when you do not know what sensor was replaced and have added little to the discussion. As it is you are left to the tender mercies of a shop that knows little about the car but knows how to replace parts, adding them to your invoice until it does start, maybe.
Old Jul 18, 2016 | 10:06 AM
lovecross's Avatar
Wink Re: no start
onehundred80 & pizzaguy are right on.
cranking w/no start is usually bad crank sensor. Chrysler part cost way too high, oem Bosch part available online, much less. If you need a shop always try to find a reputable import/German specialty shop.
Old Jul 30, 2016 | 11:15 PM
Ok, using my ninja-like powers, I found this original thread. Try to find out from your invoice/statement/bill what they replaced.
Then TELL US.
So, from what I am reading, they replaced SOMETHING and now the car turns over but won't run.
SO, did it 'turn over but not run' before they touched it? Or did it not even turn over before they changed the module? WHICH IS IT?
We have GOT to have answers to these questions in order to help you. Be patient and informative - and keep in mind that SIMPLE CHEAP stuff can fail and keep the car from starting - and yet, not set a code. That is to say, if you are not experienced with the Crossfire or the SLK320, you will be lost - as in the case with your car and your shop.
If it is turning over and not starting, the Crank sensor, the battery and a lack of fuel flow/pressure (bad pump, bad fuel filter/regulator, bad solder or relay on the RCM that feeds the pump) would be the first things I'd check.
As to fuel issues, in the Roadsters (and I BET in the coupes as well), if you are QUIET and you turn the key to "ON" BUT DO NOT TURN THE KEY ALL THE WAY TO START - (This is after the car has sat overnight), you will hear the fuel pump run for about 3-4 seconds. If you do not hear the hum of the pump OR if you hear it and it never stops humming - I think you are about to find your issue! If you don't hear the pump, the RCM relay or solder is probably the issue. If you hear it and it won't stop humming, then the pump is bad, the regulator is bad - OR the car is out of gas!
Old Aug 20, 2016 | 11:49 PM
I have my car back from shop. after they put a relay in .. it started from 3 weeks . 2 block from house it cut off and did not start again.. I hope i dont have a $6500 paper weight. The shop said that they think it the PCM/ECM but do not know for sure. I need some help please!!!!
Old Aug 20, 2016 | 11:55 PM
I took my car to a chrysler dealership and a mercedes-benz dealership and they both do not know why it will not start and run.... Both think that it the PCM/ECM !!! They did not charge me for being there. I need help ASAP!!!!
Old Aug 21, 2016 | 08:26 AM
Once again, as pizzaguy said, what are the EXACT symptoms ?
[ ] turn key, dash lights up but engine does not turn over.
[ ] turn key, engine turns over but does not start. Do this three times, then nothing when key is turned. Disconnect battery, reconnect then same 3 strikes and you are out scenario.
[ ] engine starts, idles rough, sometimes stalls.
I believe you stated that the 'relay' was replaced. was this the 'Relay Control Module' ( RCM ) ?
Have you replaced the CPS ? ( Crankshaft Position Sensor )
Is this a manual or automatic transmission ?
Old Aug 21, 2016 | 08:40 AM
If the engine does not move when you try to use the starter I would say it is the Crankshaft Position sensor (CPS).
Old Aug 21, 2016 | 10:24 AM
And I would unfortunately disagree with that diagnosis.
The CPS is not even a factor until AFTER the engine is turning.
How could it possibly generate any signals if the flywheel is stationary ?
Old Aug 21, 2016 | 10:31 AM
Yep you are correct, I am making too many mistakes lately. I knew that but still wrote down my answer.
I am not going to bother here too much anymore, stick to newer interests.
Old Aug 21, 2016 | 03:24 PM
lovecross's Avatar
Wink Re: no start
Look, even we Canucks can make a misstatement, OMG! New girlfriend? We'll keep it confidential! "If the engine does not" fire...(no spark: probably crank sensor but "ecenterprise" not helping him/her self much with lack of info/effort.)
Old Aug 21, 2016 | 04:57 PM
Please recheck yourself, Any input is better than none. I know you can contribute to the masses! Sometimes, people think they do not count, BULLSHEIT!.
Stay... get it?
Old Aug 21, 2016 | 07:56 PM
I've been here a LONG time, over seven years, gotta tell ya Dave - that is the FIRST time I've seen you make a mistake.
Pretty damn good record, if you ask me.
