Fan control module/ ABS ESP issue
Old Aug 5, 2016 | 04:04 PM
chevyboyac's Avatar
Default Fan control module/ ABS ESP issue
My car overheated and blew a hole in the coolant overflow tank, i've fixed that issue now I have a issue with the root cause of that. My fan does not come on and I have a low coolant light on, also my brake lights won't turn on and my ABS/ESP light is on. I have looked at the forums (https://www.crossfireforum.org/forum...nt-go-off.html ) which tel me it's probably either the fan control module or the fan. Does the fan control module also have any ties to ABS/ESP? I think a part failed that controls both of these functions, but the manual doesn't give me any info. Thanks for any info!
Old Aug 5, 2016 | 07:09 PM
Default Re: Fan control module/ ABS ESP issue
Keep in mind that the low coolant light is not a low coolant light - what it is meant to tell you, is very little.
Several things can light that light:
  • Coolant level too low
  • Temperature of coolant too high
  • Failure with the engine cooling fan (in this case, it means that the PTCM either cant' communicate with the Fan Control Module - or it can, but the FCM is indicating it has a problem)
  • Perhaps other stuff I don't know about
It is NOT a "Low Coolant" light, it is a "Hey, something is wrong with the cooling system, take this car to a dealer right away and pay them anything they charge you" light. If they wanted you to know anything more, the PTCM would display it in the odometer display.
I THINK that I read here somewhere that if the system sees the brakes being applied and the brake light not coming on, (meaning the brake light switch is bad or Fuse 2 in the ICM is blown) that alarm light will come on. Again, I THINK I read that here - but other than that, I got nothin....
Old Aug 5, 2016 | 08:43 PM
chevyboyac's Avatar
I pulled my fan off and hooked it to my battery and it wouldnt turn on so I bought a new one and it works like a charm now and that has fixed my low coolant light, but now I get a loud clicking on a pair of solenoids?? that wasn't there before anyone know what the heck these are for? (Right next to the battery) Imgur: The most awesome images on the Internet
Old Aug 5, 2016 | 10:01 PM
chevyboyac's Avatar
Coolant circulation valve found it.
Old Aug 5, 2016 | 10:33 PM
See? The FCM saw that the fan motor was not responding and sent the indication to the PTCM that there was a problem - and the PTCM lit the light!
AS to the valves, I can't say I've ever heard them but I DO know they do pulse on and off in response to your temperature wheel settings.
barks
May 13, 2016 07:14 PM
godthehamster
Dec 9, 2015 11:10 AM
Marvin Hickman
Feb 18, 2004 10:59 PM
prowler39
Jan 15, 2004 01:38 PM
Rwright2
Sep 18, 2003 04:55 PM
