FM signal booster location
Old Sep 8, 2016 | 09:34 PM
Ben-Hur's Avatar
Default FM signal booster location
Does somebody know where the SIGNAL BOOSTER FM AM ANTENNA AMPLIFIER AMP MODULE OEM A1938200189 is located on the convertible model? Is it near the antenna or near the radio ?
Thanks
Old Sep 9, 2016 | 04:42 PM
Default Re: FM signal booster location
It is all in the service manual - which you can download right here on the forum.
Old Sep 17, 2016 | 04:38 PM
Ben-Hur's Avatar
Hello,
I got the roadster model and I didn't find any specifications on the manual
Old Sep 17, 2016 | 10:55 PM
It is my understanding that the roadsters do not have the amplifier - they don't need it, as they use a conventional whip antenna.
I've owned three of them, done almost all work (repairs and maintenance) myself and have never found an amplifier in the antenna line.
Old Sep 17, 2016 | 10:59 PM
And I just verified my post above in the service manual - there is no amplifier.
Old Sep 18, 2016 | 09:54 AM
Shamrock's Avatar
I believe it is built into the antenna base, may be just with nav radio. Mine has two wires going to the antenna from a connector block just above and to the rear of the driver's side rear wheel. One is the power lead from the radio and the other is the coax for the antenna.
It is accessible with the top at half-mast, rear window up and top cover up. Be aware, after 10 minutes or so, pressure is released and the rear window and top cover will come down.
Old Sep 18, 2016 | 10:03 AM
Shamrock's Avatar
Hope this helps. From the 2005 Service Manual, Section 8, Wiring, Audio System
File Type: docx
Old Sep 18, 2016 | 03:21 PM
I do not believe that is accurate. The manual (and not just in this case, but in so many instances) contradicts itself. What do I mean? take a look from the same manual. If there is an amplifier in there, then doing ohmmeter measurements is a waste of time.
Old Sep 18, 2016 | 07:21 PM
Ben-Hur's Avatar
According to the schema, there is a booster integrated into the base of the antenna.
Old Sep 19, 2016 | 09:37 PM
But then why the ohmmeter checks? Oh, that's right - the manual was written by someone with a third grade education in electronics. Silly me.
Old Sep 27, 2016 | 04:51 PM
Shamrock's Avatar
Just verified --- the amp is a printed circuit board in the antenna base. held in by 2 screws under the gasket.
Old Sep 27, 2016 | 09:56 PM
Ben-Hur's Avatar
So the signal is already amplified... and optimisation for far fm stations is already done.
Old Sep 28, 2016 | 07:14 AM
Shamrock's Avatar
Presumably. According to comments on this forum and on the MB forum, there have been some problems with the coax from the antenna to the radio. You might also want to check that voltage is being applied to the amp when the radio is on. There is a connector block just below the antenna where you can check it (if you are a contortionist). Good luck.
Old Sep 30, 2016 | 10:06 PM
Ben-Hur's Avatar
Thanks all !
onehundred80
Jun 28, 2018 07:18 PM
Sebastien_L
Aug 14, 2016 10:18 AM
Veneycrossfire
Aug 10, 2016 03:34 PM
xfireruinedmyholiday
Aug 7, 2016 10:29 PM
XF redo
Aug 3, 2016 01:28 PM
